Golden Era Game of the Week 8/6/05: Robotron: 2084
http://www.gegotw.net/
Post by Weehawk » Fri Aug 12, 2005 9:47 pm
Results:
1st: BBH
2nd: Don Hayes
3rd: TJT
No last minute surprises.
BBH takes 1st and all 6 bonus points for 16 total.
Don't forget about the further bounties.
http://www.gegotw.net/robotronresults.html
http://www.gegotw.net/news.html
Post by Weehawk » Sun Aug 14, 2005 11:09 am
As an added incentive (and just because I think this is a cool design):
Anyone bettering BBH's 609,250 before October 31, 2005 will receive this Robotron T-shirt:
Your choice of size.
Requirements:
1) Only MARP members who have submitted at least one recording prior to this announcement are eligible.
2) Only one T-shirt will be awarded per member.
3) Inp and .wlf files must be submitted within 48 hours of recording and will be posted as attachments in this thread. (You may do it or I will do it for you).
4) You must, of course, be willing to give me your mailing address.
Post by BBH » Tue Aug 16, 2005 6:36 am
am I eligible if I beat that score myself? :P
Post by Weehawk » Tue Aug 16, 2005 7:03 am
BBH wrote:am I eligible if I beat that score myself? :P
Certainly.
Post by Weehawk » Sat Oct 22, 2005 5:33 pm
Just a reminder that there's a little over a week left on the further bounty here.
Also, if you use WolfMAME .101, your recording would be eligible to submit to Twin Galaxies, should you choose to do so.
Ahigh
Post by Ahigh » Mon Feb 12, 2007 11:11 pm
I just hit a million at difficulty 10 on a real machine for the first time today. I couldn't find anywhere else on the 'net that would appreciate this feat, but I had to announce it somewhere as it's been a big quest of mine for several years now.
- Ahigh
Post by BeeJay » Tue Feb 13, 2007 12:13 am
Do you still find it easier on the real machine than even the latest Mame releases where they have some fixes for the difficulty problems?
Either I am total crap at this now, or it is still slightly harder than the actual machine was on the same settings.... either that or there is still no substitute for the actual arcade controls into an actual arcade machine versus going into a PC and being interpreted as keypresses.
Post by BBH » Tue Feb 13, 2007 12:22 am
I feel the same way, that even with the fixes in MAME it's still considerably harder compared to the arcade. I've never played an arcade machine on level 10 though, but on default difficulty it is much tougher for me to "marathon" it on MAME than it is on the actual machine.
Post by The TJT » Tue Feb 13, 2007 5:48 am
Aaron, It's now possible to submit at MARP using diff=10 with robotron.zip.
DBH and BBH have pulled off passing the big M here. Might be something to do with initials.
Ahigh
Post by Ahigh » Thu Mar 15, 2007 6:43 pm
I plan to Marp up what I got skill-wise soon, and I'll report back. I have a lot of stuff to say about all this, but I have to wait until I get all my ducks in a row.
Thanks for the interest and responses. I'll report back soon.
- Ahigh
Ahigh
First tidbits
Post by Ahigh » Wed Apr 11, 2007 9:42 am
On my laptop just now, robotron runs significantly faster under emulation than the real cabinet does. This causes the game to be more difficult under emulation.
It reminds me of a speedup chip for asteroids.
My understanding is that the real robotron slows down depending on the amount of activity, and that, in general, the tuning of how much it slows down (if it even slows down at all on my pc) is off.
It seems to me that the correct approach to get a 100% faithful emulation under mame you should create a 6809 interpreter that counts the number of instruction cycles and tries to hit real-time for the clock-speed of the 6809. I don't think cache is involved on a 6809, so it should be easy enough or at least doable.
The other thing that I don't know yet is what's the total time in milliseconds of the feedback loop on a real cabinet versus under emulation.
You can figure this out to the nearest 16 milliseconds using a video camera that can see both the controls and the video screen.
The smallest feedback loop would be if on the original hardware, there is drawing to the screen memory directly with no double buffer (likely as doubling the video ram would be expensive back then). In addition, if the custom input hardware on the original machine is set up to sync the polling on the controls to the time immediately before the movement of the players character from the game code's update player position routine, that could eliminate an additional 8.3 average milliseconds compared to using, for example, a USB connected controller with a regular 10ms polling period that is not synchronized to the 16ms update rate of the video display. IE: USB and other PC input devices poll at independent update rates of the video display which can cause beat frequencies obstructing optimal firing timing.
On level 10, it is critical that you can push in a direction at the exact moment in time to kill a spheroid that is trying to avoid your path of bullets. It's smart!
The beat frequency between 100 hz and 60hz would cause a variable lag in the input, where the actual lag value would vary from 0ms to to 16.5 milliseconds along the path of a sine wave at 40hz centered at the average lag of 8.3 milliseconds. IE: you would get sporadic lag in your inputs, with lag values alternating at a 40hz frequency.
I have no idea about the details of how Mame is implemented, and it is possible read usb input other ways, but it is less likely that Mame is doing it this way just wild-ass-guessing (for usb devices).
I don't know about PS/2 keyboard (EG: hotrod) re: typical poll rates or if it is typically read through interrupt versus polling and if polled what rate the polling is done.
But I do have a hotrod and a groovy game gear usb, so I should be able to tell if the hotrod is better or not.
in opengl, drawing to the frontbuffer is easy, but in directx, I think frontbuffer access is maybe more complicated at best. Assuming that Mame has a priority of keeping all games more similar, it might be using double buffering on the Mame version and single buffering on the real hardware(?)
But, absolutely, at least on my machine with whatever default settings I had on wolfmame32-0100 on my laptop, it's noticably faster, and thus more difficult. Even if Mame is doing single buffer, the faster speed would more than likely be more difficult than the slower speed. Unless, of course, you have a problem adapting to firing at a slower pace when the machine slows down as you do on a real machine (fire too fast, and you miss bullets .. normally I think there's at least 33ms between shots, but at half speed, you can actually wiggle the joystick between two directions so fast that a bullet doesn't come out).
These are my immediate thoughts.
I will hookup up hotrods and groovy game gears tomorrow and report back soon.
- Ahigh
Post by mahlemiut » Wed Apr 11, 2007 10:30 am
I'm pretty sure MAME does cycle accurate emulation of the 6809. In any game that slows down due to the speed of the emulated CPU, then MAME is likely to be running it just a touch faster than the actual arcade, as wait states aren't emulated.
As far as I know, no driver in MAME emulates wait states, largely due to there not being any easy way to implement it in MAME as yet.
As for the controls, MAME only polls digital inputs once per frame. Typically, this is all most games need. MAME checks analog inputs only as the game requests the data, and can be (but isn't necessarily) numerous times per frame (for accuracy). There is certainly some inherent delay in control responsiveness, but this can't really be helped.
Ahigh
Post by Ahigh » Thu Apr 12, 2007 2:51 am
mahlemiut wrote:I'm pretty sure MAME does cycle accurate emulation of the 6809. In any game that slows down due to the speed of the emulated CPU, then MAME is likely to be running it just a touch faster than the actual arcade, as wait states aren't emulated.
Well, I played, but I didn't do very well at all yet. I got 305K on my second game and it went downhill from there. I was using perfect 360's with slikstick stainless steel balltop replacement shafts on a groovy game gear usb keywiz 49-way hardware setup (switches appear as joystick buttons rather than as keyboard buttons). Part of the problem was the controls for sure. The throw is so long and the weight of the ball so heavy, you're fighting inertia of the stick itself. My real cabinet has happ competitions, and the clicky feedback helps a lot more than i realized. And my motor memory is tuned to those by now. I got the replacement happ comps from tornado terry out in texas, and I highly recommend them as the best robotron controllers at this point.
I have suzo joysticks and I think I will order another pair of tornado terry's red-balltop happ competitions and try both of those.
The game didn't seem as fast using joysticks as it did using the keyboard, so there may have been a psychological factor in not being as good at the keyboard and thinking it was just too fast because my motor memory isn't there.
I'm hopeful I can build some controls and get back in there, but so far, I can't translate my million score on a real cabinet into wolfmame. I'll keep the forum posted.
Also, I was playing on an LCD on a lapop, and I know there is resizing latency when you put that laptop into any non-native res, so running in a window I think is the way to go on that to avoid too much upscaling-related display lag from non-native res. Open to suggestions, and willing to run on a crt too, which i may do to eliminate as many variables as possible.
- Ahigh
The setup I played on
Post by mahlemiut » Thu Apr 12, 2007 7:20 pm
Like I said, digital inputs (joysticks, buttons) are likely to be once per frame, and analogue inputs (trackballs, spinners, pedals) maybe once per frame, maybe more. Certainly relative analogue inputs would need more than one check per frame, to keep it as accurate as possible. Absolute inputs would probably only need one check every frame (or so), as whenever it's checked, the value returned is the exact position it is in.
Ahigh
Post by Ahigh » Mon May 07, 2007 8:17 pm
mahlemiut wrote:Like I said, digital inputs (joysticks, buttons) are likely to be once per frame, and analogue inputs (trackballs, spinners, pedals) maybe once per frame, maybe more. Certainly relative analogue inputs would need more than one check per frame, to keep it as accurate as possible. Absolute inputs would probably only need one check every frame (or so), as whenever it's checked, the value returned is the exact position it is in.
On the accuracy point, a zero that should be a one because of the progression of time is arguably more wrong than a 0.35 that should be a 0.37...
On my real cabinet, I scored 1.93 million April 27, 2007. I have also scored over a million on that cabinet 4 times by now (again diff 10, xtra 25k, 3 men to start). I haven't yet gotten my controls and displays all set up to make a better attempt at home, but I will be trying soon.
- Aaron
