Puzz Loop 2 split
Puzz Loop 2 split
Stage mode, Power mode, Panic mode (I think, plays like a panic mode, don't know what "tokoton" means in English).
Stage Mode and Power Mode are split, cool. but there is third panic mode which is like the old panic mode. I guess -cm? or maybe make the -pm panic mode and make -wm power mode.
-tm, maybe - for Tokoton mode (which it is called)? But then, it might be worth doing the same for Puzz Loop as well, which is also called "Tokoton mode"
Tokoton does mean panic, that is if the first puzzloop got the translation right. So adding -tm as the old panic mode should work for the new puzzloop 2. So from the start of the game there are 4 modes, first is Stage Mode -sm, rotating clockwise (moving to the right) when -sm is on the botom you have Tokoton Mode which is an old style panic mode, going one more to the right you have the 2 player mode, and completing the loop (or to the left from the start) you have the new -pm power mode (mine and barry's current recordings are in power mode).
btw the 5-5 stage is a 4 track nightmare... but completable.
Post by ***PL*** »
Added:
pzloop2j-tm "Puzz Loop 2 (Japan 010205) [Tokoton Mode]"
