Namco Classics Collection Vol. 2 [Digdug Arrangement]
http://marp.retrogames.com/inp/1/2/a/le ... mame86.zip
Goes immediately into sound test. (Using console version, but should be no difference)
Post by QRS »
Same here..(using gui version)
zlk
Post by zlk »
Doesn't work for me either.
That's three strikes - zeroed.
lippsman
Post by lippsman »
I just played it back fine on my machine. Are you using the .86u3 version?
zlk
Post by zlk »
I used mame32v86u3. Do you have any special settings like -nosound or -noafs?
lippsman
Post by lippsman »
no special settings. I downloaded the Mame Exe. file from http://www.classicgaming.com/mame32qa/down.htm
Although they have version .86u4 listed now instead of .86u3. Although, I imagine that it would still play back fine.
mahlemiut, where did you get your version of Mame to post your Inp of this game?
Thanks
Louie
Standard source release from mame.net, patched to u3 from the "official" patches. I'll try it with u4 in a few moments (have to re-compile first).
lippsman
Post by lippsman »
Thanks
lippsman
Post by lippsman »
I just downloaded the .86u4 version and it doesn't get past the sound test. I checked the 86.u3 version one more time and it worked on all 3 computers. Give the re-compile a try. And if that doesn't work. Post a exe. that I can download and I will record the inp with that version. So we know that it will work.
Thanks
Louie
Nope, same thing under MAME 0.86u4 too. :(
lippsman
Post by lippsman »
Could you post a link to the version you are using so I can record the inp with it. Or should I just wait till Wolf comes out with support for the Namco games?
It's not a huge deal. But as you see from my scores. I have a thing for Dig Dug
Thanks
Louie
Just the plain source (http://www.mame.net), patched with the u1,u2, and u3 source updates (http://haze.mame.net). I'd rather not upload a binary for bandwidth reasons (dialup sucks).
this is late but i can't get this inp to get out of the blank screen that comes up, shortly after the attempt at initing. I'm assuming this is the "sound test" but i can't really tell since everything is black. Pretty strange if you can play it back lips, would definitly want to find out the cause of that...
lippsman
Post by lippsman »
I'm going to record an inp on 84u4 and post it here before I upload. We will see if that works.
