Today morning I record inp for psychos. Score 1793750, but I can't playback it correctly. Something wrong is on last stage. If I use throtlt (F10) when playback then I died in middle last stage. When I playback without F10 then all is OK until my first lost on last boss.
I record in wolf78 with sound on and frameskip auto.
I post my inp here.
Maybe somebody can playback correctly this inp.
ATTACHMENT DELETED
psychos
- destructor
psychos
Nope.
With frameskip 11, I got 793,750 once and 708k once.
With frameskip 0, I got 793,750. Does not beat the last boss.
Some games are frameskip-sensitive. Autoframeskip is a bad idea. Find a specific frameskip rate that gives you acceptable speed and use it. Playback with the same rate will have a better chance of succeeding.
"fire...fire...psycho soldiers..."
- destructor
OK. I try finish game with frameskip 0.
EDIT
I recorded with frameskip 0 and playback fine. But can't use throtle when playback. Must be playbacked in normal speed with frameskip 0. (maybe can use F10 until last stage - I didn't check it)
http://marp.retrogames.com/inp/e/0/8/dt ... wolf78.zip
I delete my file from first post becuse is useless.
EDIT
- destructor
One problem more. Psychosj.. I record inp with frameskip 0 and can't playback it. Something wrong is on stage 5. Maybe no sound is required.
wolf78.
http://marp.retrogames.com/inp/9/b/2/dt ... wolf78.zip
wolf78.
Can you try to playback this inp? It's worked perfectly for me the twice I've watched it.
http://isweb37.infoseek.co.jp/play/mame ... ay/781.zip (Save Target As...)
MAME Plus 0.83 (WolfMAME Plus 0.83 will do)
Should finish with 1.66 million.
- destructor
- destructor
Hehe. After computer reset my inp playback correctly. With normal speed (no F10). Uploaded to MARP.
Time to analysis and beat LIBRINIAN's score.
- destructor
For me works OK if I playback in normal speed and Frameskip 0.mahlemiut wrote: I suggested that you try the inp I gave a link to, it's that inp that worked twice for me.
But this inp is very poor
PS. Yesterday I finished psychos with no throw any one bomb
