kof2000
kof2000
Doberman.jp,
http://marp.retrogames.com/inp/9/9/5/mo ... _win84.zip
http://marp.retrogames.com/inp/d/b/7/mo ... _win84.zip
My apologize for editing these two recordings assuming they were nvram problems, barry notified me that these are probably -bios setting playback problems. We really want to keep these scores on marp if they playback correctly, so please upload again and tell us what the -bios setting is set to so everyone can use the known settings to playback these recordings?
I suspect someone will find out what the correct setings are to play these back once they are posted here... I'll be trying to guess which -bios settings they are as well, since i REALLY wanted to see these playback.
Don't forget the 68000 CPU core options to. Each core will have to be checked with each BIOS too.
no matter he's uploaded some more beatifull scores that are default bios compatible, thanks doberman.
I and Kuba from HotTeam can't playback inps from Doberman.jp. When game run error appear: "MEMORY CARD ERROR". How I can playback Doberman's inps from kof2000 and kof2000n?
check your ini files for bios setting and remove it, the default (not set) bios setting should work, and make sure to delete all files in the memcard directory before playing or playing back.
btw, clark does the station to station super throw in the 2nd stage, Round 4 (i
http://marp.retrogames.com/inp/0/d/b/mo ... wolf86.zip
my favorite fighting move of all time :)
