http://marp.retrogames.com/inp/c/f/f/sc ... lf85u2.zip
Does not playback, assumably recording at the game is not fixed yet.
...Just damn much slower and even more much bigger inp size. 1minute play is about 25MB of unplaybackable bytes.
I assume this is the case with other G's 720 recordings also, I don't bother to check. Those clones didn't playback previously and surely do not now either:
http://marp.retrogames.com/index.cgi?mo ... &short=720
I'm sure those do not playback for Gerhard either, check your recordings before submitting. Save us trouble. Game should be unplayable slow when recording anyway.
Only 720 and 720b should work at earlier mame versions, if service mode trick is performed.
Gerhard's 720 recordings
No go here either, they just end up resetting, no matter what. I weep for the poor MARP server and these huge inps. :(
Zeroed.
EDIT:
http://marp.retrogames.com/inp/4/a/5/jy ... wolf83.zip
I only get 300. (but really... 1700? I'm trying not to be elitist here, but... really, why bother?)
Zeroed.
EDIT:
- Gerhard S
- MARP Serf
this recording dont work also
http://marp.retrogames.com/inp/3/d/b/jy ... wolf83.zip
i use this mameversion
http://wolfmame.marpirc.net/wolfmameplus-083u1.zip
all record must be deleted (so wie meine !!!)
Gerhard & Crew Pinballs
http://schindler-gerhard.de/
yes, no playback.Gerhard S wrote:this recording dont work also
...Only 720.zip and 720r2.zip playback, if near mame36 version is used.
Gerhard, please, please, please try your recordings yourself, before you submit to marp...Allways.
If can not playback own recording, then sure nobody can not playback it.
Good luck for climbing leaderboard
Thnaks
BBH wrote:http://marp.retrogames.com/inp/4/a/5/jy ... wolf83.zip
He wants world to see?
...Or testing playbackability, before KILL!
