Mame .85u1 [Mameplus to be followed by Wolfmame Plus?]
Posted: Fri Aug 13, 2004 7:52 am
by Mr. Kelly R. Flewin
0.85u1
Driver Improvements:
- Fixed input port definition errors in megasys1. [Mamesick]
- Fixed input port definition errors in tnzs. [Inigo Luja]
- Fixed input port definition errors in taitosj, galaxian.
[Aaron Giles]
- Changed 720' controls to use an analog joystick instead of a
dial so that the original controller motion can be replicated.
Thanks to MAME Analog+ for the logic. [Aaron Giles]
- Fixed the colors in the Status trivia games. [Stefan Jokisch]
- Conditional DIP switches in rallyx, mcatadv, galpanic.
[Inigo Luja]
Changes to the main program:
- Fixed loading of ctrlr files so that they actually take effect now.
[Aaron Giles]
- Fixed bug preventing saving of lightgun control changes.
[Aaron Giles]
- Changed all the analog mapping defaults back to 'keyboard' as the
default values were confusing people. [Aaron Giles]
- Added the ability for analog axes to return "invalid" as a value
from the OSD layer, allowing them to dynamically disable themselves.
Using this feature, the Windows version now autodetects analog
versus digital axes and dynamically disables the analog values if
it thinks you are using a digital axis. Note that this even works
if you have a "switchable" gamepad. [Aaron Giles]
- Fixed debugger crash when using F10 with the i960 core. [R. Belmont]
- Cleaned up some #ifdef MESS and united the two definitions of
my_stricmp. [Rene Single]
New Non-Working games / clones supported
Party Time: Gonta the Diver II [Brian Troha]
Versus Net Soccer (ver JAB) [Brian Troha]
Phraze Craze [Pierpaolo Prazzoli]
Tic Tac Trivia [Pierpaolo Prazzoli]
Trivia Whiz [Pierpaolo Prazzoli]
Trivia Whiz II [Pierpaolo Prazzoli]
Posted: Fri Aug 13, 2004 8:13 am
You're bored. Right? :)
