http://marp.retrogames.com/inp/6/9/5/sc ... _win84.zip
Never starts. NVRAM, perhaps?
I also question his system speed to run this game at an acceptable rate. His T8 inps show a clock speed of around 2GHz. Assuming that that is a Pentium-based system, then that is not enough.
Mr. Driller
Mr. Driller
- Gerhard S
- MARP Serf
this is my record
is my machine to slow for this game ?
i use mame32 0.84 - wolf0.80 will not start this game
what version is better for this nice game ?
Gerhard & Crew Pinballs
http://schindler-gerhard.de/
http://wolfmame.marpirc.net/wolfmameplus-084u1.zip
You can disable interlacing for a speed up. (In test mode, go to Display Test, change "Interlace" to "Non Interlace").
- Gerhard S
- MARP Serf
I can´t find this option in wolf0.84u1mahlemiut wrote:http://wolfmame.marpirc.net/wolfmameplus-084u1.zip
the game not run with this version
- Gerhard S
- MARP Serf
oh ! Thanks - it works - but to slow for me with my athlon 2400Buttermaker wrote:Or just press F2.
Works just fine.the game not run with this version
BTW Gerhard. Leaderboard points you see when submitting an inp are leftovers from old leaderboard system.
Current leaderboard ranks players with the number of 1. place scores. (if 1st place scores tie with other player, then amount of 2nd places etc...)
So if you want to climb LB, one 1st place score beats 1000 2nd place scores.
Yet, if you are PROUD of your score at a game, you should submit it, even if your submission would get only 15th place.
just incase you didn't know
Tommi
Tommi
