Having a problem playing back Metrackle's recend upload. Only plays back to 20 some thousand. Using Windows XP.
http://marp.retrogames.com/inp/a/c/7/me ... wolf80.zip
Thanks
Rampage Playback problem
Moderator: giro-X
what operating system are you using? thanks. note, rampage will usually only playback with the operating system that recorded it, xp and 98 being the big distinction. 2000 and xp will proly be the same.
also looks as if john has found the problem, it may be one of the dlls in mem you may need to remove before trying to playback these.
Version of OS
I'm using XP. Why don't we have a drop down menu when you submit a score where you can pick the OS that was used for the inp.
Just an idea.
Thanks
Louie
Just an idea.
Thanks
Louie
I can't play that inp back either. I would say that it's Metrackle that needs to look for a DLL to remove.Chad wrote:what operating system are you using? thanks. note, rampage will usually only playback with the operating system that recorded it, xp and 98 being the big distinction. 2000 and xp will proly be the same.
- destructor
Re: Version of OS
Write to description Win98 or WinXP.lippsman wrote:I'm using XP. Why don't we have a drop down menu when you submit a score where you can pick the OS that was used for the inp.
Just an idea.
Thanks
Louie
