kof99
kof99
http://marp.retrogames.com/inp/0/b/6/kr ... wolf81.zip
with sound bao is first opponent, jung wins but in a desynched way, then kensou kicks some a. with out sound mai is first opponent and beats jhun, either way it's all zeros.
Mr. Kelly R. Flewin
Re: kof99
Post by Mr. Kelly R. Flewin »
Chad wrote:with sound bao is first opponent, jung wins but in a desynched way, then kensou kicks some a. with out sound mai is first opponent and beats jhun, either way it's all zeros.
I beg your pardon? Bao?? Xiangfei is the first person I fought. It also played back perfectly on my end, so here's my stats to perhaps aid.
P4 2.8Ghz
1 Gig DDR400 Ram
Windows XP Pro SP1
Sound On
FSKP 0
Bios: US MVS [Ver. 1]
CFG File: None
NVRam: None
YES IT IS A BIOS ISSUE!
I just tried it with [US Ver. 2] and I got Mai as the first character! [I'm using the Mame Plus NeoGeo Bios btw]
We have to make this as an annoucement, as I can see issues rotating around this. Try using Ver 1 and let me know. I will edit the score msg to reflect this as well.
Kelly
The default BIOS (-bios 0) should ALWAYS be used. We had enough fun with the different regions in Neo Drift Out. At the very least mention which BIOS you use in your description (I presume you didn't, I haven't looked).
Mr. Kelly R. Flewin
mahlemiut wrote:The default BIOS (-bios 0) should ALWAYS be used. We had enough fun with the different regions in Neo Drift Out. At the very least mention which BIOS you use in your description (I presume you didn't, I haven't looked).
Okies... um... what's default bios? [twitch] I use WolfmamePlus32... so clarification will be of much helpfullness. I also changed my info on the recording to reflect this bios] Sorry for problems :(
Kelly
I'm pretty sure that it's a Europe BIOS... not sure of the exact description. Just set 'bios' to 0 in mame.ini.
Mr. Kelly R. Flewin
mahlemiut wrote:I'm pretty sure that it's a Europe BIOS... not sure of the exact description. Just set 'bios' to 0 in mame.ini.
Well I just changed it to 0 on ame.ini .... nothing changed under the bios settings... so we'll see what happens now.
Kelly
thanks for actually posting the bios value you had in your mame.ini before you changed it to 0 (not), works -bios 1 and -bios 2 starts with mai, with -bios 3 it works, which i guess is the US MVS bios option value.
Mr. Kelly R. Flewin
Chad wrote:thanks for actually posting the bios value you had in your mame.ini before you changed it to 0 (not), works -bios 1 and -bios 2 starts with mai, with -bios 3 it works, which i guess is the US MVS bios option value.
Actually... it's kinda funny... when I went into the INI, [before I was informed that it could be changed in there] this was the exact line.
Bios=Default
no numbers whatsoever... kinda confused the crap out of me really, as I figured there'd be a number instead of the word. I don't know if the 0 option is going to work though.. as it doesn't seem to change the bios option in the GUI... or as long as I have it set to 0 in the INI file, it won't matter?
I mean there were a LOT of diff Bios settings in the GUI as well, so I'm curious as to what Bios 0 is...
Kelly
SYSTEM_BIOS_ADD( 0, "euro",       "Europe MVS (Ver. 2)" )
SYSTEM_BIOS_ADD( 1, "euro-s1",    "Europe MVS (Ver. 1)" )
SYSTEM_BIOS_ADD( 2, "us",         "US MVS (Ver. 2?)" )
SYSTEM_BIOS_ADD( 3, "us-e",       "US MVS (Ver. 1)" )
SYSTEM_BIOS_ADD( 4, "asia",       "Asia MVS (Ver. 3)" )
SYSTEM_BIOS_ADD( 5, "japan",      "Japan MVS (Ver. 3)" )
SYSTEM_BIOS_ADD( 6, "japan-s2",   "Japan MVS (Ver. 2)" )
