Tombstones Audit
Metrackle
Mutant Puzzle Freak
Tombstones Audit
Post by Metrackle »
Note: Not all of the recordings are listed (Skipped the following games on purpose: All Taito F3 games, All CPS2 games, Gunbird 2, and Armed Police Batrider).
http://replay.marpirc.net/r/airbustr
http://marp.retrogames.com/inp/0/e/8/tm ... mame61.zip
5010
http://replay.marpirc.net/r/boblbobl
http://marp.retrogames.com/inp/f/b/4/tm ... mame61.zip
At over 900000, strange behavior happens: a two player game is begun, and both players constantly jump left and blow bubbles.
http://replay.marpirc.net/r/bubblesp
http://marp.retrogames.com/inp/4/a/8/tm ... mame61.zip
Doesn't go anywhere.
http://replay.marpirc.net/r/bucky
http://marp.retrogames.com/inp/a/0/0/tm ... mame61.zip
Doesn't even register a coin.
http://replay.marpirc.net/r/cawing
http://marp.retrogames.com/inp/d/1/c/tm ... mame61.zip
Crashes into service mode at 130770.
http://replay.marpirc.net/r/cosmognj
http://marp.retrogames.com/inp/e/e/2/tm ... mame61.zip
20390
http://replay.marpirc.net/r/crossbow
http://marp.retrogames.com/inp/6/3/d/tm ... mame61.zip
Coin Mech Jammed
http://replay.marpirc.net/r/darius2
http://marp.retrogames.com/inp/7/4/e/tm ... mame61.zip
Tilts at 493020.
http://replay.marpirc.net/r/dsaber
http://marp.retrogames.com/inp/3/a/4/tm ... mame61.zip
19100
http://replay.marpirc.net/r/knckhedj
http://marp.retrogames.com/inp/4/2/4/tm ... mame61.zip
8400
http://replay.marpirc.net/r/mach3
http://marp.retrogames.com/inp/9/8/b/tm ... mame61.zip
33600
http://replay.marpirc.net/r/othundu
http://marp.retrogames.com/inp/e/6/f/tm ... mame61.zip
Coin Error at 22400
http://replay.marpirc.net/r/peterpak
http://marp.retrogames.com/inp/2/e/f/tm ... mame61.zip
5261
http://replay.marpirc.net/r/stinger
http://marp.retrogames.com/inp/c/5/7/tm ... mame61.zip
72440
http://replay.marpirc.net/r/tdragonb
http://marp.retrogames.com/inp/e/d/8/tm ... mame61.zip
188400
http://replay.marpirc.net/r/tp84a
http://marp.retrogames.com/inp/0/0/b/tm ... mame61.zip
240100
http://replay.marpirc.net/r/valkyrie
http://marp.retrogames.com/inp/2/f/1/tm ... mame61.zip
1900
http://replay.marpirc.net/r/volfied
http://marp.retrogames.com/inp/d/8/6/tm ... mame61.zip
241540
Reason: fixing links
Re: Tombstones Audit
coin op error goes to 22400, I'm third, edited score.
154370 plays ok with out nvram, looks like someone else confirmed it
I get same strange behavior at 900k, need third to change score, the zip is also corrupted which is the likely cause here.
Playsback ok with default nvram, this is a nvram problem, passed the grandfather date, zeroed.
Crashes into service mode at 130770, need third to change score, the zip is also corrupted which is likely the cause.
This playsback fine for me at 910770, I confirmed it.
Coin Mech Jammed, I get same, need third to zero, has corrupted zip.
Tilts at 493020, I get same, need third to change score, has corrupted zip.
19100, I get 9000 every time, with or with out default nvram, need third to zero
This playsback fine with out nvram but to 28600, I edited and confirmed.
33600, i also get this, it was already confirmed.
5261, that's the score with out nvram, the score with default nvram is 627921, zeroed due to nvram infringement.
72440, corrupted zip, need third to change score
188400, looks like wrong recording, playsback fine to 188400, was already score changed and confirmed.
240100, was a likely typo, already scored changed and confirmed.
1900, I get a desync and AAAAA sig at 40,300, need third to change score,
241540, I get the same, already edited and confirmed.
Chad wrote:http://replay.marpirc.net/r/boblbobl
http://replay.marpirc.net/r/*boblbobl
Same scenario encountered. Didn't recognise it for what it was at first but it continues with multiple credits as the death-ghost (whatever) kills them off). Edited to 900000 and confirmed.
Chad wrote:http://replay.marpirc.net/r/cawing
Same here - service mode at 130770. Edited and confirmed.
Chad wrote:http://replay.marpirc.net/r/crossbow
Same here - corrupt zip & Coin Mech Jammed. Zeroed.
Chad wrote:http://replay.marpirc.net/r/darius2
Tilt at 493020. Edited and confirmed.
Chad wrote:http://replay.marpirc.net/r/dsaber
8400 without NVRAM for me. Zeroed.
Chad wrote:http://replay.marpirc.net/r/stinger
De-syncs around 60K probably due to the corrupt INP. 72440 final score. Edited and confirmed.
Chad wrote:http://replay.marpirc.net/r/valkyrie
40,300 here too. Edited and confirmed.
