these submissions don't playback . Note in the latests mame version (over 060) inps playback only without sound in this game.
http://marp.retrogames.com/inp/5/7/6/mr ... _win58.zip
Playback to 2160 with/without sound/nvram
http://marp.retrogames.com/inp/f/b/9/te ... mame56.zip
Playback to 960 with/without sound/nvram
Francois
punchout
actually, the game is very picky for playback.
Even in 0.60, my punchout inp only totally correctly plays back if I am using the same audio rate...AND the speed throttle MUST be on.
if you are watching these with the throttle off that's likely why they aren't playing back correctly. Try them again with throttle on and also varying the audio rate if one wasn't supplied with the submission.
I'm guessing frameskip also matters. punchout is about as picky as they come for playback.
- Francois Daniel
As I said, in the last versions it playback only with sound off. For these one I try them with throttle but don't playback.LN2 wrote:actually, the game is very picky for playback.
Francois
Ok, you didn't mention trying them with throttle on also.
I have not tried punchout since 0.60. Maybe I'll do a quick run to see if it's an issue in the latest macmame. I'm guessing it won't be an issue in macmame as none of the other games in pc-mame that only record/playback properly with audio off have that problem in the same version# of macmame.
these are no goes, tried lots a differnt frameskipings , only thing tha really seems to affect the playback score is sound or nvram, none of which make it passed hurricane. third?
