Should the NVRAM be allowed in HS?
Yeah, it's like the arcade, you get a good head start on the first round pointswise. I can't be bothered to work it out, but i said elsewhere a possible 72k is available 1st round (based on a Pole Vault of 5.92 being the lowest record), obviously decreasing (and moving closer to what non NVRAM recordings will be at) by later rounds.
But, and it's a bit selfish: I can't use it. I'm not prepared to have dozens of different versions of mame, so that I can record an inp for this without being called a cheat for using autofire or the mysterious technique of 'slowdown' (and thus include an NVRAM before recording)..
I use Wolfmame, I can't use an NVRAM yet 72k on my inp would catapult! me to second I think.
The thing is, it's very VERY hard to get a record of 5.92/3 on the first round which would enable a good scoring opportunity on the second and subsequent rounds. Bear in mind that the run-up speed doesn't increase til the third round; basically youre stuck with struggling to hit high heights for 2 rounds because of this (and thereby set the record that you need to allow massive points.)
IMO, this is possibly about the best you can expect on a first round run of HS without the NVRAM (assuming perfect Pole Vault jumps all the way):
Swimming: about 13000 MAX (thats sub 45seconds)
Skeets: 14200, 16200, 19200 (im a bit stuck here, cos i've seen 21200 in arcades, but not sure if that was first round - I cant get 19200 anyway heheh) - 49600
Long Horse: 9.65, 3 times, just over 12500 points - I've had 9.65 a couple of times on the 1st round.
Archery: Fck knows - 4600 x 3? Can't remember what happens at apples, wanna say [edit] 3k bonus, then 3 x 1k (what after that tho? ok sao i did do it
Triple Jump - Again not too sure, I reckon you get about [edit] 5.5k per (good) jump - so say 16k.
Weight Lifting: About 15-16k - Big lifts, bonus dependant. I got about 15500 lifting 520kg with no bonuses I think :/
Pole Vault: Assume 5.91. Assume no NVRAM, you can get ABOUT 19k. With a good NVRAM, say with records at 5.92+, you're looking at about a possible max of 85k.
Anyway vote or not
