Upload problem
sampras
Upload problem
Post by sampras »
Hi all,
I 've problem to upload any INP.
Sorry
Sampras
Buttermaker
Post by Buttermaker »
You could edit one of your old posts.
Luja
Post by Luja »
I can upload nothing too. :cry:
Buttermaker wrote:You could edit one of your old posts.
That only allows you to edit the score and description...it doesn't allow you to replace the zip archive you originally uploaded. you have to resubmit through the submit page to replace that.
Buttermaker
I'm talking about this message board.
Buttermaker wrote:I'm talking about this message board.
Ok, well even in that case..if you just edit an old thread/post then it likely won't get the attention the person wants cuz the dates for the thread and "new" status aren't changed when you only edit a post I think.
...so I could edit a post in a 6 month old dead thread and likely no one would even notice it...cuz it still would be grouped in the same spot with all the other 6-month old dead threads.
Buttermaker
The case here is that sampras does not want attention which is why I'm suggesting that he edits an old post.
Sampras and Luja,
Have you tried uploading from a URL instead of directly from your computer?
To do this go here
Sampras, now that you have the file here on the board (as Buttermaker suggested you could have used an old post) you should be able to use:
download.php?id=98
as the URL.
Buttermaker
Sampras and Luja,
Haha, why do you think sampras attached the file to his post?
Buttermaker wrote:why do you think sampras attached the file to his post?
When I first read the post I thought he was wanting someone to take care of it for him. (As did Rick apparently)
After your reply I figured that's what he was probably doing but didn't check to make sure.
I was mainly explaining for the benefit of Luja or anyone else who might not have known you could submit from a URL.
John
re....
I can't upload either... ( a score for 'ssi' )
Cheers ,
sampras
Post by sampras »
Still have upload problem :cry: :cry:
sampras
Post by sampras »
Still
Buttermaker
Then you wouldn't have to make new posts and bump this thread each time.
Frankie
Post by Frankie »
sampras wrote:](*,)
Still
How fast is your connection Sampras?
Frankie
