sfposeid
Posted: Tue Jul 01, 2003 12:56 pm
by Q.T.Quazar
JSW's sfposeid fails to play back to the advertised score. I have him to 7790, with or without sound. There is an obvious desynch somewhere. Seems to me the taitosj.c was problematic for a number of .36 betas, as I used to have some bad Wild Western .inps from around the same time period.
Anyway...
http://marp.retrogames.com/inp/f/e/b/js ... _m36b3.zip
Posted: Tue Jul 01, 2003 3:10 pm
by kfx
Same here, no matter what settings I use.
Re: sfposeid
Posted: Tue Jul 01, 2003 4:21 pm
by Mr. Kelly R. Flewin
I can't even get this one to work, with or WITHOUT sound... it keeps coming up with a baby blue screen and the word "TILT" in white...
Kelly
Posted: Sun Mar 25, 2007 7:22 am
by tar
Posted: Sun Mar 25, 2007 7:44 am
by destructor
What OS you use to playback it?
Posted: Sun Mar 25, 2007 10:51 am
by tar
i used windows 98.
the mame emulator states that this game Does Not Work Properly
type ok
m35tg3
windows and dos
Posted: Sun Mar 25, 2007 11:00 am
by destructor
I think it should be test under DOS with sound.
Posted: Mon Mar 26, 2007 2:19 am
I'm getting the same result for the top sdposeid score with win35tg3, although i can't vouch for the dos side, If tar is getting the same screen as shown in dos then this appears to be a playback problem and i'm 2nd. Des can you try? There are no emulation differences between the b and the non b versions if my memory serves me right.
Posted: Mon Mar 26, 2007 4:06 am
by destructor
Chad wrote:Des can you try?
Not. I have WinXP on my both PC now. But maybe I will try to give life my old HD and I will try to run DOS only on it.
Someone remember how run sound card in DOS? I have integrated sound card on ASUS motherboard.
Posted: Wed Mar 28, 2007 11:49 am
by Phil Lamat
I still have w98 & 35tg3 on my old PC.
But game doesn't work, only works correctly since m36b2.
Beejay has probably selected the wrong version when uploading, or upload a bunch of inp made with m35tg and forgot to turn this one to the good version.
I've tried with several dos versions, and managed to pb to around 2500 seeing a good gameplay, then desync
Posted: Wed Mar 28, 2007 7:12 pm
by tar
phil lamat wrote:Much better this time around [game isn't playable with m35, it's only working since m36b2 ; so probably a mistake selecting version there -- PhL]
i used 36 beta 11.
old 150mhz.
desync
[/img]
Posted: Wed Mar 28, 2007 7:17 pm
by Phil Lamat
I've tried with later versions like m55 according to the date of submission.
But maybe there is also a playback problem
Posted: Thu Mar 29, 2007 2:33 am
I can't play it back but i can get the tilt message to go away when i use XP -nosound and mame36b15 through mame36final and mame37b1, which is probably the latest version that could have been used for a recording dated 2000 April. Maybe if someone were to try with sound with any version in that range.
Posted: Thu Mar 29, 2007 2:15 pm
by Phil Lamat
Chad wrote:mame37b1, which is probably the latest version that could have been used for a recording dated 2000 April.
BeeJay's input is from 2001.
He mailed me that after I edit his recording :
"I guess I probably selected the wrong version when I uploaded the game. It
was definitely working with the version I recorded it with, and playing
exactly as I remember it in the arcades. I'll try and find some spare time
to play this game again real soon to beat this score and get rid of the
unplaybackable version."
