vblockbrk Revisited
As it relates to vblokbrk...disabling sound seems to work fine, my case especially since enabling sound caused crashes mid-game, desynching and below-regulation game speed (which was already a given since suprnova games in MAME run like they have Parkinson's anyway..). The same applies to Saru-Kani-Hamu-Zou but without the desynching...
「シューティング ラブ。」
yeah that's the whole case of if you want your recordings to be viewable by all people with the same os, then just submit to http://marp.retrogames.com/index.cgi?mo ... 00&tourn=0 the other vblockclone since that was before 62. But you want those extra clone points dont you ? :)
*can someone move this to playbackabilty i screwed up the board split function again :)
the doomed recordings to only playback in one set of machines (not necesarily with the same os) can be found at http://marp.retrogames.com/index.cgi?mo ... 00&tourn=0 (just adding links)
