3kokushi : split ?
3kokushi : split ?
I think 3kokushi should be split in easy & normal mode (-em & -nm ?)
You've only 3 stages in easy modes, more in normal but all stages are very different
Pat, what do you think ?
Francois Daniel
Re: 3kokushi : split ?
Post by Francois Daniel »
Phil Lamat wrote:I think 3kokushi should be split in easy & normal mode (-em & -nm ?)
I agree with you Phil. Furthermore, the Easy mode is really very easy to complete, and normal mode is very hard to complete even firsts stages.
Francois
I don't see much need for the split, personally. The maximum that can be achieved on the easy mode can be surpassed on the normal mode. Already there are numerous scores that are very similar on easy mode. It isn't difficult to master & therefore would warrant *'ing if they were split, IMO.
Blost
Post by Blost »
Barthax wrote:I don't see much need for the split, personally. The maximum that can be achieved on the easy mode can be surpassed on the normal mode. Already there are numerous scores that are very similar on easy mode. It isn't difficult to master & therefore would warrant *'ing if they were split, IMO.
Same case as Pang3 beginner/normal mode in that case...
Francois Daniel
Exactly, you find the right example :)
Francois
I think: "no split" or "only normal mode" because in easy mode max points is 350300 and this is easy to make (every will be 1st on easy mode).
Frankie
Post by Frankie »
destructor wrote:I think: "no split" or "only normal mode" because in easy mode max points is 350300 and this is easy to make (every will be 1st on easy mode).
I agree on this. It should only be allowed to make uploads on normal mode. It's up to Pat to decide.
Frankie
Post by ***PL*** »
Agreed -- normal mode uploads only for now on. We can "grandfather" the easy recordings thus far.
Pat
