Ln2's Jack Rabbit inp
zlk
Post by zlk »
I tried to get this to playback in Windows (mame32) but it doesn't work for me:
http://marp.retrogames.com/inp/ln2_jack ... mame60.zip
Maybe someone else can try? Sorry rick :cry:
Try in mame60 instead. That's what I tested it in VirtualPC(running Win98) on my mac before submitting and it played back fine.
I didn't test it in mame32-60.
It might be one of those that is M$Windows version dependent also so if you are running WinXP that might be why it won't playback for you also.
confirmed, works fine when playedback with regularmame and windows xp, do you have win98 zlk?
zlk
Post by zlk »
I have windows XP. I just tried the win32 version of mame. Strange that it did not work for me. :( I am glad it worked for someone :D
make a backup of your mame.ini and unzip and copy this to your mame dir and try to see if it makes a difference.
Thx for confirming Chad. :D
zlk
Post by zlk »
I finally got around to trying the command line version from the command promt and the inp played back fine. Even with the ini it wouldnt play back with mame32.
Nice play Ln2.
