My guess is that you need to upload your default.cfg and viewpoin.cfg files as well,but it's strange,in theory save states are mainly for bug testing -> a talented player plays,saves the state and the developer use it for fixing purpose.sikraiken wrote:I'm not sure how well save states transfer from machine to machine, but it's attached (wolfmame106).
K7 - Round 1 - Part 2 - View Point (viewpoin)
Re: K7 - Round 1 - Part 2 - View Point (viewpoin)
Alright, here are those files. Make sure "Enable game cheats" is selected as well (under miscellaneous), or else the save state doesn't work I think. These files go in the cfg directory.
Stage 3 1-up requirements:
-Destroy the two black balls at the same time.
-Destroy all centipedes.
One time I got a star instead of a 1-up, somehow. Ghemant, a star is better than a 1-up score-wise (in-game scoring), but not with how your targets are set up. ; )
- defaultandviewpoin.zip
- (770 Bytes) Downloaded 447 times
yes, I'm unison with yousikraiken wrote: Ghemant, a star is better than a 1-up score-wise (in-game scoring), but not with how your targets are set up. ; )
but....
every life = max 200.000 pts if you are a very good player in this game.
Again, your targets.GHEMANT wrote:yes, I'm unison with yousikraiken wrote: Ghemant, a star is better than a 1-up score-wise (in-game scoring), but not with how your targets are set up. ; )
but....![]()
If you want a high score without miss lives, you can obtain all 14 Nazo bonus
I don't know for others, but for me target A sucks : it forces me to restart level 1 80% of the time.
Should be able to claim the bonus if target has been reached once, even not in final inp
Maybe if I had a VHS tape of the arcadia record like some people... ; )
Ok, now I got it to work and can indeed get the 6 stars very easily now doing the same things I was doing with my own state. Have no idea what the difference could be. Have you ever managed to get the 6 stars on a complete regular game?
I also noticed that using your state, the satellites near the end drop a star as the 3rd last item (lower right side of the screen). No matter what I do on my games I always get an F bomb (heh). Noticed the items there are sometimes bombs when you are in need of them but even with full bombs I always get the F.
Similar problem with the 1 up, I destroyed everything starting from the first bee wall and only got an F right before the caterpillar crossing.
VHS isn't sufficient because arcadia record is with autofire. If you use autofire you obtain a nazo bonus with facility. But if you don't use, all game change. After many years, I can say that high score (like arcadia) is possible also without autofire, but all pattern change.sikraiken wrote:Maybe if I had a VHS tape of the arcadia record like some people... ; )
It still gives you the great benefit over everyone else of seeing where the nazo are. I'll be getting the Mission Impossible 2, anyway.GHEMANT wrote:VHS it isn't sufficient because arcadia record is with autofire. If you use autofire you obtain a nazo bonus with facility. But if you don't use, all game change. After many years, I can say that high score (like arcadia) is possible also without autofire, but all pattern change.sikraiken wrote:Maybe if I had a VHS tape of the arcadia record like some people... ; )
Yeah, I've managed to get 6 stars in a complete regular game. For the end of stage 6 and 1-up in stage 3, it seems like you need full bomb stock.The_Pro wrote:Ok, now I got it to work and can indeed get the 6 stars very easily now doing the same things I was doing with my own state. Have no idea what the difference could be. Have you ever managed to get the 6 stars on a complete regular game?
Ok, figured some things out. In order to get the six stars and the 1-up on the third level you must have three bombs, one of each kind. I didn't keep going but I'm 99% sure that this will also give you a star for the 3rd last item that would otherwise be an F.
In addition, you don't have to kill the black orbs on level 3 at the same time. I went the whole way without bombing.
I don't even know if I'll have time to take advantage of this, so swamped. If I don't upload something else by tuesday night then I won't at all.
The_Pro wrote:Ok, figured some things out. In order to get the six stars and the 1-up on the third level you must have three bombs, one of each kind. I didn't keep going but I'm 99% sure that this will also give you a star for the 3rd last item that would otherwise be an F.
this game is so silly.
Thanks for figuring that out, Martin.
- ballas
- MARP Knight
What is nazo?
KVD
Koos van Dyk
Johannesburg
SOUTH AFRICA
Koos van Dyk
Johannesburg
SOUTH AFRICA
Your ship's side pods, which is equivalent to picking up a gold star if you already have them.ballas wrote:What is nazo?
