K7 - Round 1 - Part 1 - Golden Axe (goldnaxj) no magic rule
- ballas
- MARP Knight
Re: K7 - Round 1 - Part 1 - Golden Axe (goldnaxj) no magic rule
Can we submit a score without finishing the game? Just a querry for the ppl who are some of the lower scoring in this game? I keep getting killed on the last damn boss!!!
KVD
Koos van Dyk
Johannesburg
SOUTH AFRICA
Koos van Dyk
Johannesburg
SOUTH AFRICA
Yes indeed. You can also get those recordings, although I only found that out recently. If you go to marp.retrogames.com and search for goldnaxj, you'll see the top three scores. For the rest, click the goldnaxj link, it looks like this:Can we submit a score without finishing teh game? just a querry for the ppl who are some of the lowest scoring in this game? I keep getting killed on the last damn boss!!!
Click that link and you'll see all of them.Golden Axe (set 4, Japan, FD1094 317-0121) (goldnaxj)
- Marco Marocco
- MARPaltunnel Wrists
ATTENTION: if MARP's site is down, remember you can send the zip files attached at the posts here in the forum
- ballas
- MARP Knight
Thanks, MARP is actually down at the moment. Here's my replay for K7.
- goldnaxj - 958 MARP.zip
- K7 - Hensachi = 95.8
- (27.62 KiB) Downloaded 423 times
KVD
Koos van Dyk
Johannesburg
SOUTH AFRICA
Koos van Dyk
Johannesburg
SOUTH AFRICA
- INNUENDO
GHEMANT wrote:sorry but....INNUENDO wrote:I´ve made my objective. Targets B and C. That´s enough. Back to the studies.
Target B is missed because: stage 3, enemy n. 4 dead on the ground [score is 80 and not 84]
however, congratulations for target C, you are the first player that made it!
Oh, that´s true. Sorry for my mistake, Ghemant. You are right. And thanks about target C. I confess was very difficult to me do that.
Anyway, I´ll go back to the studies. Maybe in this weekend I´ll try again. But I´m satisfied with this result.
Here's my latest attempt. Slowly getting there.
Meanwhile, looks like ZTNet has screwed something up again. Zwaxy says it doesn't appear to be fixable from this end, so we'll just have to wait for ZTNet to fix it. Fun.
EDIT: Looks like it's back up already.
- br_k7_goldnaxj_1175.zip
- K7 - Hensachi = 117.5
- (23.95 KiB) Downloaded 404 times
Flop (@) 430score is mistake, score correct is 443, Mahlemiut please correct because I can't re-write correct score.
- ballas
- MARP Knight
Thanks, Verty. I have seen it and I'm finding my way around much better on MARP now that I'm getting use to it. I have submitted my 1st .inp now. Hopefully I can improve on this.verty wrote:Yes indeed. You can also get those recordings, although I only found that out recently. If you go to marp.retrogames.com and search for goldnaxj, you'll see the top three scores. For the rest, click the goldnaxj link, it looks like this:Can we submit a score without finishing teh game? just a querry for the ppl who are some of the lowest scoring in this game? I keep getting killed on the last damn boss!!!Click that link and you'll see all of them.Golden Axe (set 4, Japan, FD1094 317-0121) (goldnaxj)
KVD
Koos van Dyk
Johannesburg
SOUTH AFRICA
Koos van Dyk
Johannesburg
SOUTH AFRICA
No need to do that each time, just set "worst position to show" to 100 instead of default 3, and you will have the whole tableverty wrote:If you go to marp.retrogames.com and search for goldnaxj, you'll see the top three scores. For the rest, click the goldnaxj link
Thanks, that'll be much quicker.Phil Lamat wrote:No need to do that each time, just set "worst position to show" to 100 instead of default 3, and you will have the whole tableverty wrote:If you go to marp.retrogames.com and search for goldnaxj, you'll see the top three scores. For the rest, click the goldnaxj link
Then, I've found some extra points which Ghemant may or may not know about. I've sent him a PM about it.
- INNUENDO
The_Pro wrote:Thanks goes to INNUENDO and his incessant rolling for giving me an idea.
I´m very curious to see your replay, The_Pro. Congratulations for you!
I´ve seen that you did more than 400,0 points, but here in my job I can´t see inps. I´ll watch in night.
Very nice trick!!!The_Pro wrote:Thanks goes to INNUENDO and his incessant rolling for giving me an idea.
Not useful if you play normally because you can make that skeleton fall with magic, but... excellent
I can almost see my first place being smashed after K7 hehe
sorry, I have mistake (again
) in the sum of points for MISSION IMPOSSIBLE... I write a incorrect number (I had calculated 0,5 pts less in a passage), correct is:
4 ? ? , 0
thanks Verty!
4 ? ? , 0
thanks Verty!
remember all strategies of 3 years ago on my guide?MJS wrote: Very nice trick!!!![]()
Not useful if you play normally because you can make that skeleton fall with magic, but... excellent![]()
well.
after 3 years you can add other 35.5 pts from new technics and secrets
What if you throw dragon in the pit ?
Just did a game with a funny trick!
I have thrown the dragon in the pit with the enemy while killing it.
As i am not as good as some of you, no idea of the amount of points i got. Do you have an idea
Jerome
