Thanks.mahlemiut wrote:http://wolfmame.marpirc.net/xwolfmame-0106.tar.bz2
There could possibly be a few compatibility issues between MAME and X-MAME, but certainly for this game, there aren't. I can confirm any X-WolfMAME 0.106 inp if need be, anyway.
K8 - Round 1 - Part 1 - Bubble Memories (bubblemj)
Re: K8 - Round 1 - Part 1 - Bubble Memories (bubblemj)
- el_fumador
- Button Masher
I have uploaded an inp recently but it seems to have problems after pressing the "Send" for overwrite or something similar.
I attach it here:
I attach it here:
- bubblemj.zip
- K8
- (101.28 KiB) Downloaded 1531 times
Alright, I'm not very bright; what was the key to getting enemies to turn into food? I did it on accident but couldn't quite figure it out.
On stages 1,5,15,25,35,45,51-59, and 65 (and 75?) it is automatic.
It is also automatic if you get the candy cane on that stage.
Otherwise, you must match the 10s and 100s digit of your score when you kill the last enemy on the stage. Any extra empty bubbles touching the bubbles popped will change the score also, so you should take that into account.
It works exactly the same way as it does in Bubble Bobble.
mahlemiut wrote:On stages 1,5,15,25,35,45,51-59, and 65 (and 75?) it is automatic.
Ahhh, thank you. I've never really played Bubble Bobble with any seriousness but I guess there's no excuse for not figuring it out.
For info :
"bubblem" and "bubblemj" now have a split called "-sm" for Super Mode
Code for Super Mode : press "Left, Start, Fire, Jump, Up, Down, Start, Right" at the title screen.
You will unlock another set of 80 levels.
I've looked quickly, it seems much harder
For anyone who's wondering why their range was not constant throughout the game, it's because the pink candy gives +range.
So if you die you lose the pink candy, which means your bubbles don't go as far.
(Just in case anyone didn't figure this out)
The king of lamer - winner of K8
I post here for reminder, Barry have found a code for "Round select" :
down, start, bubble, jump, left, start, right, start
A red "Round select" appears, but it doesn't seem to work at first use.
Maybe it only let's you select rounds that you've reached before or something ?
So, is my previous (verified) entry not to be re-instated?
