K6 - Round 1 - Part 2 - Pole Position II (test track)
Udirnel
Re: K6 - Round 1 - Part 2 - Pole Position II (test track)
Post by Udirnel »
sawys wrote: PLAYBACKS ONLY WITH NVRAM (please follow indications on my 2nd post)
45.670 - Udirnel
Oops, sorry sawys. I'll follow your instructions carefully.
Udirnel
Udirnel
Post by Udirnel »
Bummer!! I create the nvram file but polepos2.nv still appears :(
Any solution?
Udirnel
PeterPunk
Post by PeterPunk »
Udirnel wrote:Bummer!! I create the nvram file but polepos2.nv still appears :(
Any solution?
Udirnel
Udirnel, con
mame -createconfig
creas un archivo llamado mame.ini. Lo abres y allí verás
# CORE OUTPUT DIRECTORY OPTIONS
cfg_directory             cfg
nvram_directory           nvram
memcard_directory         memcard
input_directory           inp
state_directory           sta
snapshot_directory        snap
diff_directory            diff
comment_directory         comments
pues lo cambias por
cfg_directory             cfg
nvram_directory           <NULL>
input_directory           inp
state_directory           sta
diff_directory            diff
English:
With line:
mame -createconfig
you'll create a file called mame.ini. Open it and look for this:
cfg_directory             cfg
input_directory           inp
state_directory           sta
diff_directory            diff
and change it for this
cfg_directory             cfg
input_directory           inp
state_directory           sta
diff_directory            diff
PD: Sorry for my english
Gerhard S wrote:next try -- and now i delete the nv-ram before i play
http://marp.retrogames.com/inp/f/8/5/sc ... olf119.zip
i hope this works for you
It works good ! Thank you :-D
Gaplus
Post by Gaplus »
There are of the problems with the highscores shipment automatic .
It writes to me "some kind of error with the zip file - couldn't unzip it
command: '/usr/bin/unzip -l rex_polepos2-test _55830_wolf119' "
I enclose my score here. :roll:
rex_polepos2-test_55830_wolf119.zip
K6 first try.
(58.35 KiB) Downloaded 339 times
Gaplus
Post by Gaplus »
Now 56710..
rex_polepos2-test_56710_wolf119.zip
(53.38 KiB) Downloaded 338 times
Udirnel
Post by Udirnel »
Gracias, Peter Punk. Parece que funciona.
Udirnel
saru3000
Post by saru3000 »
Thanks from me too, Peter Punk. I'm lazy and hated having to remember to delete the nvram everytime.
dbh
Post by dbh »
Sawys, there's a typo on my score listed in this thread. As much as I would like to have scored 56K+, my current real score was 46,970. Oddly enough, my position in the list is currently correct :)
gameboy9 submitted an excellent run...
please add "K6" to the description though so it appears on the K6 leaderboard and so the ref sees it as well.
deadful_melody
Post by deadful_melody »
LN2 wrote:gameboy9 submitted an excellent run...
Gameboy9 is a tournament coordinator and thus is not eligible for the leaderboard.
However, he is first in the "unofficial" tournament coordinator's leaderboard, listed just below the main leaderboard in the first post of this thread.
~ Paul McCallon
gameboy9
Post by gameboy9 »
dbh wrote:Sawys, there's a typo on my score listed in this thread. As much as I would like to have scored 56K+, my current real score was 46,970. Oddly enough, my position in the list is currently correct :)
Got it. :)
Thank you. :) But Deadful Melody is right - I'm a coordinator and therefore can't rank in.
http://gameboy9.marpirc.net
re...
Couldn't you guys pick a game without all this extra baggage?
Luckily I have a friend who can translate all this stuff for me.
Not sure if others are so lucky.
Seems like a lot of unnecessary messing around to play and record a game.
Meh....
Al, It's not that hard, it's the usual stuff, only the instructions were very detailed. :)
at Command prompt:
mame polepos2 -record polepos2 -mouse
tab,
Input this game(you only need these two buttons for playing:
Player1 pedal inc (=gas)
Gear change
Adjust analog settings for dial x sensitivity, it's too sensitive.
I always use simple read-only file called "nvram" (no filename extension), which prevents mame ever creating nvram-directory. Create this file by creating nvram.txt, rename it to nvram, rightclick properties, check read-only. Put it in your mame directory. voila
Larcen Tyler
Post by Larcen Tyler »
BBH wrote:is there any point in even having a brake button without analog control? I tapped it once and couldn't get back up to full speed again. Maybe because it thought the pedal was partially pressed down or something. I've just disabled the button entirely since letting go of the accelerator provides a pretty big speed drop in the first place.
As a long time fan of Pole Position, I can tell you that based on what I read in GamePro's review of Namco Museum Vol. 3, their protip for the game pretty much matches my advice, in that you don't need the brakes. Instead, simply use high and low gear to slow down around turns, and/or let off the accelerator.
By the way, is there a way to make it so your car will center itself once you let go of the key, or do you have to recenter it manually?
