T13 - Round 4 - batcir
Moderator: giro-X
Re: T13 - Round 4 - batcir
CPS-2 games have never had issues before. I'd just make sure they aren't using default NVRAM.
Ladies and gentlemen!
(I'd say... more gentlemen...
I've solved up to now every trouble with past Battle Circuit INP of yours.
Get a refresh on the ranking of this game only
Round 4 - batcir
# Name Score TP Day 7 TP Day 28 Status
1 SFCHAMPION 1681400 12 100 OK
2 mahlemiut 1480600 10 88 OK *claimed 1460800*
3 Mr. Kelly R. Flewin 655300 8 38 OK
4 Krj 626200 7 37 OK *finally :)*
5 AGODZILLA@AIVA 537000 6 31 OK
6 xelnia 427000 5 25 OK
7 Fordy 422000 4 25 OK
8 kernzy 212500 3 12 OK---
giro-X (also LUX, Luke, Red Ryuu) - member of Mame Retro Avengers team
[about my team]
[my MARP profile]
[YouTube channel with replays of stuff I did for or outside MARP]
[For contact on Telegram - state who you are please]
[about my team]
[my MARP profile]
- simpsons99
what has changed on this rom set since wolf 142 .. I can not get it to work with 152 or others but wolf106 and wolf142 works fine?
Arcade Game Scores
Arcade Game Scores
giro-X wrote:Important notice
The romset name is: batcir
BUT
To make the game work properly, you need also the romset: qsound
- simpsons99
TY
mahlemiut wrote:giro-X wrote:Important notice
BUT
Arcade Game Scores
Arcade Game Scores
Watched SFCHAMPION's INP. Definitely requires default NVRAM. MARP general rules require no NVRAM to be present.
Re-checked, thanks. Wolf B. has the truth.mahlemiut wrote:Watched SFCHAMPION's INP. Definitely requires default NVRAM. MARP general rules require no NVRAM to be present.
(The score was also confirmed in Marp, whoops.)
[about my team]
[my MARP profile]
[about my team]
[my MARP profile]
Starting to get the groove back...
- br_t13-batcir_2218700.zip
- Stage 6, lost to Zipang. 2,218,700. T13, SDL, 64-bit
- (968.39 KiB) Downloaded 1106 times
Shoulda used another Death Blow...
Have to post a link - just crept past the 1MB limit.
http://mahlemiut.marpirc.net/br_t13-batcir_2681400.7z
2,618,400. Stage 7. SDL, 64-bit
Slight improvement. Lost to Pluto. I hate Pluto.
http://mahlemiut.marpirc.net/br_t13-batcir_2808300.zip
2,808,300. Stage 7 boss. Still needs work. T13, SDL, 64-bit
For saulonpb: I don't know if this is the reason why Battle Circuit is not working to you on wolf 0.152, but I repeat it, in the case you may have not noticed.
troubles in running the application with the proper game are not a valid reason to switch version, because it can always be fixed so our aim would be to be able to run it (it would rather be troublesome for some users to run "ancient" versions of MAME, not the newest).
when then the application is running properly, if the recording speed is too slow, you are permitted to use older version, but we should see first an example of "bad" recording with speed troubles.
Since we are trying to limit as much as possible the use by players of the 0.106 version of WolfMAME,giro-X wrote:Important notice
BUT
[about my team]
[my MARP profile]
[about my team]
[my MARP profile]
- simpsons99
He is always trying to make his own rules
giro-X wrote:For saulonpb: I don't know if this is the reason why Battle Circuit is not working to you on wolf 0.152, but I repeat it, in the case you may have not noticed.
BUT
Arcade Game Scores
Arcade Game Scores
Just a bit of fun, I enjoy using Yellow Iris, but find it a bit more difficult. So this is a bit more sucky, but was fun.
http://mahlemiut.marpirc.net/br_batcir_iris_2m.zip
Better score... slowly getting there...
http://mahlemiut.marpirc.net/br_t13-batcir_3002600.zip
3,002,600. Stage 7. Still hate Pluto. And Asura. :/ T13, SDL, 64-bit
Marginal improvement... Need to stop the stupid deaths.
http://mahlemiut.marpirc.net/br_t13-batcir_3088200.zip
3,088,200. Stage 7. Rank S x3.
