k6 - round 3 - Ghosts'n Goblins [Time Trial]
Udirnel wrote:
Francois Daniel wrote:AAAAAAAARGH !!!!!
RE-AAAAAAAAAAAAARRRRGGGHHHH!!!!!
:cry: :cry: :cry: :cry: :cry:
¿May I participate although I'm out of the contest? (The "issue" that put me apart of K6 was born yesterday :wink: )
Udirnel
Sorry, you can play the game and send it here to show your skill but your score won't be included in the round 3 because we have already the 18 players.
Cheers.
gameboy9
Post by gameboy9 »
Yeah, we'll use WolfMAME+'s frame counter to determine time. It'll be +/- a second, unless it's close in determining either the top 12 or the seeding of the top 12, in which we'll look at them again to be precise to the frame.
http://gameboy9.marpirc.net
Nanni
Post by Nanni »
Udirnel wrote: (The "issue" that put me apart of K6 was born yesterday :wink: )
Udirnel
WOW :D :D
Congratulations, but now you need to buy a really small joystick :wink:
About the game... im really close to my first complain :( , all the thing seem a little bit confusing :?
When playbacking:
Press f11 to see framecount (frameskipping doesn't seem to have effect). See how many frames your recording had (from start to last stage finished?).
Divide that frame number by 60 to get seconds played. (Do we really need this?)
Perhaps no need for framecounting on early submissions?
With all courtesy, I think this is a total fuckpig game. ](*,)
Nanni
Post by Nanni »
The TJT wrote:When playbacking:
I think "time"/"Number of Frames" makes sense as score system if the majority of players can finish the game (probably i can't :( (<-- this is a bit optimistic i can't for sure :cry: :cry: )) if we don't think about finished games time is only a tie breaker, but, in thi case we have problems defing main score: "level" is too rough... and maybe the sub-section too... everything imo 8)
Maybe this game setup was better in h2h scenario?
:roll:
NotMan
Post by NotMan »
Why don't GB9 come up with the similar idea that Phil did on WCC6 round 1 (TangTang). I think that scoring system may work on time trial for gng.
Good luck on Top 18. Thank God, I don't have to play that game and I haven't even played for years.
Btw, Marco... GnG wasn't popular here in states in the parts of where I'm from. I have seen it once, long time ago. Used to play GnG on C-64 version, but it is harder than arcade version. :wink:
NotMan
Blost
Post by Blost »
NotMan wrote: Used to play GnG on C-64 version, but it is harder than arcade version. :wink:
NotMan
depends on the arcade set you're playing :)
and the C64 only had 4 levels.
anyway i had a good start but failed miserably...
bs_gng_132100.zip
Loop1 - Stage 6 / 54542 frames.
(46.63 KiB) Downloaded 476 times
deadful_melody
Post by deadful_melody »
Loop 1, Stage 4, Area 2 (Fire Bridge)
pdm-gng-1-4-2.zip
(19.74 KiB) Downloaded 442 times
~ Paul McCallon
I hate this game.
stage 3.
In stage 3 I have walk more road like corpse that like human.
gem_gng_stage3.zip
(20.13 KiB) Downloaded 468 times
INNUENDO
Post by INNUENDO »
Why you haven't put it in Round 2 ? :'(
Rafael, this one is for you :)
Yes... If this game could be putted on Round 2, you´re be the champion of the round, François!!
Well... I´ve tried. I finished the game (the complete run with 2 loops) in 31:09 min.
I´ve a question. Can use the tricks like disapear the dragon on fire bridge? The only forbidden is to leech??
sikraiken
Post by sikraiken »
Are we allowed to do this?: http://beatthegame.net/gng.zip
You'll need an MNG viewer to watch it:
http://tomspeirs.com/mnger/
Image Image Image
Stage 4
sikraiken wrote:Are we allowed to do this?: http://beatthegame.net/gng.zip
Stage 4
I think it should be disallowed, it's a bug in the game. Pete and Marco can watch it and tell what they think about it. I'm personnaly against.
sikraiken
Post by sikraiken »
http://beatthegame.net/gng2.zip (need an MNG viewer to playback)
How about this one as well (it's the one Innuendo mentioned)?
This is a time trial, and these do help a little if done correctly. Davil does the trick with the dragon. He also does a trick where he goes up the ladder in stage 6 to get the enemies moving, then he goes back down the ladder and goes all the way to the left of the screen, shoots until the enemies jump, and then goes back up the ladder. The enemies are in midair so you can walk underneath them.
Why shouldn't these things be allowed? It's not like they get rid of enemies for an entire stage, give invincibility or anything like that.
The first one that I posted a video of doesn't really matter since you don't actually gain any time for using it. The other two I mentioned in this post should be allowed though. They've been used on MARP before.
INNUENDO
Post by INNUENDO »
The coordinators will decide the "real rules", but when I made my replay, the only trick that I used was don´t fight with the second dragon (fire bridge).
In level 6, I´ve lost the armour in the two giants at the begining of the level, and I kept going up.
I didn´t use warp zone or something like that. But, if the rule is to fight with all enemies, no problem.
sikraiken wrote:http://beatthegame.net/gng2.zip (need an MNG viewer to playback)
I could be ok for the ladder, the red devil and the dragon but not for the 1st trick you mentioned because if i saw well, it's like a shortcut, no ?
