Replay Bounties III
mameplus114u3. Samplerate 44100, DirectDraw. Autofire. Playbacki fine but no crosshair. The same problem with crosshair is in official MAME version. Crosshair is during play but during playback no crosshair. Mystery game. I still search version for better crosshair work, it is strange to watch replay without crosshair.
zombraid.zip
(480.2 KiB) Downloaded 281 times
mameplus109. Samplerate 44100, DirectDraw, frameskip 0. Autofire. I test playback with F10 only -> fine. There is old crosshair version, we can see it :) Finished.
zombraid_mplus109.zip
(445.1 KiB) Downloaded 319 times
zlk
Post by zlk »
Destructor has won the following bounty:
ROM: zombraid
f) Finish the game and kill the final boss: $50
To get to the final boss you need to use crystal codes:
* Crystal Codes :
Level 2 - The Crystal Code is posted at the end of the level, on the 2 pillars framing the wrought iron gate (below the head with the horns).
Level 3 - The Red Crystal is obtained at the end of the level in the elevator.
Level 4 - The Blue Crystal is hidden in a statuette on a pillar (the statuette resembles the level 2 famous head with the horns).
Level 5 - The Green Crystal is obtained at the end of the level by killing the 2-heads monster.
To fight the final boss, the Crystal Codes seen on level 2 should be inserted : Red, Green, Blue - if not it is assured death.
I know that in game are more secrets. First secret is on stage 1 -> enter to tree. Inside is Lighting weapon. In game is Silver bullet weapon but I didn't found it.
I search it long time when I begin game on whole elevator and no red orb :D You must destroy all zombies from elevator for red orb ;)
Excellent game. Now I must found right wolfmame version for normal finish game. It is possible without autofire and without autofire hand. Easiest -> game must be no miss, use lighting weapon.
EDIT
Game not must be no miss. You must have good weapon during game -> shotgun, fire, lightning. Strongest are fire and lightning.
Finished, wolf80, autofire. Second secret entrance discovered. Score 221630.
zombraid_wolf80.zip
(251.13 KiB) Downloaded 280 times
zlk
Post by zlk »
The wolf80 replay works if I use f10.
It does not work if I try to watch it normally.
Playbacks fine : 221630 ... and no coin op error :)
Only playsback for me with F10 as well.
For me works without F10. Hm... where is key? I will use oldest wolf version today. Wait for replay.
Do you have 'enable joystick input' checked? Try to uncheck it. Do you have cheats enabled? Disable it. M68000 C Core disabled.
Wolf106 again, this time cheats were off during recording. Please disable cheats for playback. For me playback with no problem, no coin error.
click
wolf106gui-vc version.
EDIT
I record wolf109 replay, coin error during playback :( Why in mameplus109 no coin error? Luck?
zlk
Post by zlk »
I got the wolf80 replay to work. The new 106 replay does not work.
Items in second secret entrance:
1. auto-reload (no more press button for reload :))
2. extra life
zlk
Post by zlk »
ROM: indyheat
j) Score more than 76 points: $100
This bounty is sponsored by an anonymous donor.
excellent recording des! In the 2nd to last race, the yellow car was practially jumping in the air trying to beat you with turbos and you edged it out. I'm wondering if the strategy on the race you lost would be to push the yellow in to the pit, since he never pit and won by a huge margin.
Thanks. Notice that I downgraded 11 first places by this score :P
