Safety Spot
Gorf Safety Spot
It doesn't work in the gorf ROM set with current versions of MAME. If you notice, the screenshot above was from the gorfpgm1 ROM set which is better emulated. It worked in the arcades too, but the emulation for the gorf ROM set is not very accurate and has a lot of other problems besides just the safety spot not working.
-gastrainga
re....
Gaz: just leave the last laser guy,and then go extreme left and extreme up.
Should work. Must be a MAME thing. It worked in the arcades. Maybe a newer rom version made it impossible. I used gorfpgm1 ROM set .
re....
And while we're at it, lets not forget about the old Defender safe spot.
Collect all ten humanoids, wait until there are no enemies on screen, and land those MF's....
Only really works on wave one, unless you are a master. But gives you an opportunity for an early smoke etc....
defe0000.zip
(1.31 KiB) Downloaded 2023 times
Post by QRS »
Hisa:
Talking about safespots.. are there any of these on some of the later bosses in strikers 1945 plus? 1-6, 1-7, 1-8 (or the semibosses) Maybe on the second loop? Even if I need one to even get to the second loop hrm :)
Thanks
wuzel
Post by wuzel »
Commando - i think all romsets
stage 3 - behind the bunker to the right :)
while old days at arcades the chef of it while spotted some1 standing there simply cutting the power off :)
It's good 2 be here with U guys :)
Tron
The more or less famous Tron safety spot. Works at opposite corner too.
Time for a smoke, again
Novice
The greatest info supplyer
Re: Safety Spot
Post by Novice »
Raiden #8 last.
I think this is the KING of the safety spot.
DEFence CONdition
WAR 1<< >>7 PEACE
Novice
Re: Safety Spot
Post by Novice »
R-Type II boss 5.
DEFence CONdition
WAR 1<< >>7 PEACE
Novice
Re: Safety Spot
Post by Novice »
and boss 6(last)
DEFence CONdition
WAR 1<< >>7 PEACE
Kale
Re: Safety Spot
Post by Kale »
Robocop stage 5 boss
Novice
Re: Safety Spot
Post by Novice »
raiden II boss 5.
there are 3 positions.
A:side
B:back
C:front
ABAABABAABCBAABABAABCBAABABAABCBAABABAABCBAA .
after 44th attack(A), boss will escape.
The attachment 0002.png is no longer available
DEFence CONdition
WAR 1<< >>7 PEACE
Novice
Re: Safety Spot
Post by Novice »
1941 last stage middle boss.
this enemy is not very easy.
safety or 350,000points which do you want?
DEFence CONdition
WAR 1<< >>7 PEACE
