Darkstalkers: The Night Warriors (Euro 940705)
Zwaxy
MARP Founder
Post by Zwaxy »
It also says:
This recording has cheats enabled
I find I get that with all the GUI wolfmames. Is it a bug?
Chris.
Zwaxy wrote:It also says:
Chris.
Where do you read that using the gui?
Also, bear in mind that the default mame.ini has cheats enabled. Try turning them off.
Buttermaker
Post by Buttermaker »
Weehawk wrote:Where do you read that using the gui?
You can't.
No, only the default MAME Plus .ini has cheats enabled.
The problem is that enabling/disabling cheats using the GUI version of MAME Plus doesn't make a difference (from within the GUI or the .ini). Cheats are always enabled.
Cheats 0 works fine for the CLI version of MAME Plus.
Zwaxy
MARP Founder
Post by Zwaxy »
What I meant is that if I record using the GUI version and play the recording back using the command line version then it tells me I had cheats enabled even if I didn't.
I have cheats disabled in my mame.ini and in my GUI settings, but I still see 'cheat' in the in-game menu.
Looks like a bug to me.
Chris.
It's certainly a bug to do with MAME Plus. I don't have any problems myself as I don't use the GUI.
