TJT's new Tron (set 2) high
dbh
Post by dbh »
Yes we had about same cycle patterns at funspot, except one that You go straight right against the wall(hah) -I used it back then couple of times when I was not sure which cycles were next -At that time I preferred so called "joystick magazine pattern" going first up then left. But I figured out later that if I start all patterns right I don't have to remember anything, just "pattern recognizion" and play.
Yup, I've always liked that pattern :) When I show it to people, they are usually stunned at how simple it is. As you noted, the trick is to know which boards to use it on without trying to memorize the actual sequence (ie, doing it by pattern recognition). I have tried to explain that to people watching me play and sometimes it takes them a while to understand.
Same with Tanks, now I start all tanks up! I don't have to remember which tanks are next, much more fun! I think tank patterns are now about as good I can figure out.
Ah, yes, now I think I remember....at Funspot you had one or two tank boards where you went down at the beginning of the board. All my tank patterns (except for the red tanks) also go up first, shoot the tank coming across the top of the warp if necessary, then half-way down into the warp and pick off the rest of the tanks. There's really only one board where the firing sequence can be tricky. But your new tank patterns are more fun to watch than mine, I think.
I must admit that I got the Idea not staying shooting spiders from you Donald. Don't shoot them mainly because it's booring -more fast and fun like this
You're welcome :) Also, I found that it results in a slightly faster rate of scoring...maybe 20-30K/hour. That can add up on a long game of 6+ hours.
Do you leave shooting spiders at any level Donald, when there's a nice tight bunch?
Sometimes....depends on how the board is going and whether I'm playing for fun or seriously. Also, it can sometimes provide a small "break" to relax before continuing on to the next screen. You can get the screen to the point where all you have to do is shoot and not even move until you're ready to enter the tower.
Only thing that has to be remembered now, meaning which level is next -is of course fast left cone after slow...But forget that few times anyway, but managed alive!
Yup, same here. And that's not even a necessary thing to remember, it's more of a convenience to make the board slightly easier.
LordGaz
Post by LordGaz »
Played back first time for me. TGMAME32v69 (GUI), Athlon XP 2000+, sound must be on.
Nice game Tommi, I like the hiding spot you can use on the Recognizer levels as well, it looks like you had quite a break at one point ;).
Gaz
doesn't seem to playback properly on my new Hewlett-Packard P4 2.4 ghz on Windows XP. great.
ooooo... Hewlett-Crapard. :)
I still say there must be something somewhere that causes this, and something that can be changed to fix it.
have you noticed any patterns of this playback issue with games that depend on specific sound settings and require the sound on to playback?
if so, then perhaps that's the key to the issue....maybe differences in version of sound drivers or soundcard etc. result in the issue. You would think that wouldn't really matter since that is outside of MAME but given it depends on those components and those components can vary from one PC to the next maybe that's it.
Perhaps games where there are no playback issues...which are most of them...are all games that aren't particular about sound settings or even using sound to playback correctly.
This sort of fits the fact that even people using what they assume is the same OS...might have differences in drivers installed or even hardware differences in the soundcard. It also would fit why the inp always plays back just fine for the player on the same PC.
Someone that has a few different PCs that can playback an inp like this Tron inp on 1 system but can't on another maybe can do some research testing and try and figure out the exact cause...cuz they could potentially change OS or drivers or swap hardware.
I have focused on audio here but is it possible different video settings could influence the timing for playback also?
sikraiken
Post by sikraiken »
mahlemiut wrote:ooooo... Hewlett-Crapard. :)
Hey, come on, Hewlett-Packard makes decent computers. ^_^ And either way, it's certainly better than what he used to have. :wink:
Speaking of which, congrats on the new computer BBH. :D
Edit: BTW, I downloaded the INP and let it sit and playback (I have no plans of playing this game :D). Played back correctly with an Athlon XP 1800+, AlphaMAME32 .68, Sound on.
