Is this MARP policy?
Locked
Mark Longridge
Post by Mark Longridge »
Is this the new MARP policy, to just delete inps with no explanation?
I uploaded a Stack Columns inp which I know worked fine, barring the possibility of file corruption.
I want to know who deleted this file, and for what reason.
zero1@look.ca
Doesn't look deleted, the score was changed to reflect a differently
played back score than advertised by gameboy... so you might be
clicking a link that refereed to the old score but that score isn't
there but the new one is when you search for the game name.
<a href="http://marp.retrogames.com/index.cgi?
mode=search&short=^stkclmns$&table=y&per_game=1000&prefix=&passwd=&tou
rn=0"> stkclms</a>
churritz@cts.com
from the "Up" link in the "Up Loads" marp header:
gameboy9 changed score for Mark Longridge's stkclmns from 163416 to
143363
probably because it didn't playback to 163k... though no message was
put in the description of the inp. gameboy?
churritz@cts.com
Ben Jos Walbeehm
Post by Ben Jos Walbeehm »
As far as I can tell, a message WAS put in, but in the description of
the one that was zeroed out. The one with the lower score was an older
recording of Mark's, and that one got reinstated. So the one with the
zeroed out score is not visible now.
Maybe the Editors should, in those cases, edit the description of the
one that got reinstated? Something like "[Your most recent submission
of 10M on Pacman was zeroed out, because that score is impossible]".
Ben Jos.
walbeehm@walbeehm.com
Gameboy9
Post by Gameboy9 »
I saw nothing but a weird looking color-pixel test. The MARP Policy
is the recording shall begin immediatly when the first opportunity
becomes available. Please be specific next time as to what version
you are using. I believe you said you used the regular version, not
the TG2 version... GB9
goldengameboy@yahoo.com
Locked
