sspaceat2 and sspaceatc
http://replay.marpirc.net/r/sspaceat2
http://replay.marpirc.net/r/sspaceatc
Both seem to suffer the same playback issue of the parent ROM set (seems logical):
http://replay.marpirc.net/index.cgi?mod ... t=sspaceat
VERSION TO USE : m33b4 or any version since m37b15 (because this game doesn't playback with other versions)
The special rule from sspaceatt hasn't been applied to the older clones, however. I've been through each of the outstanding clones' replays and confirmed where possible. QCN has already tried in the past and leaves notes which mirror the parent symptom.
Re: sspaceat2 and sspaceatc
yep this is a clear symptom of an old verified playback problem where we don't need the third confirmed playback failure to justify zeroing. All recordings made with the wrong mame version, assuming you can verify the wrong mame version was used, are guaranteed playback failures.
I've updated the rules and edited recordings for
no need to edit rules for http://replay.marpirc.net/r/sspaceat3 because it was introduced after 37b15
