The following fail to get past the Factory Settings process probably either due to NVRAM or F3:
http://replay.marpirc.net/inp/d/3/3/tco ... olf140.zip
TehChos3nOn3 - 73,540
http://replay.marpirc.net/inp/7/d/b/os_ ... _m36b7.zip
Osman Shahaj - 45,880
http://replay.marpirc.net/inp/4/0/7/gas ... _win62.zip
gasparesollena - 42,130
http://replay.marpirc.net/inp/4/f/f/db_ ... _m36b2.zip
GameGuru - 33,080
bubbles - non-starters
Re: bubbles - non-starters
all 3 are confirmed to not playback with out nvram, 2nd for zeroingBarthax wrote:http://replay.marpirc.net/inp/d/3/3/tco ... olf140.zip
GameGuru - 33,080
this one uses a default nvram. don't remember the grandfather date to allow nvram recordings or not, so i just confirmed it with a note,
The "grandfather date" is in the rules, rule 2f :
From 15 September, 2001, the use of nvram files is prohibitied
For other inputs, I will check in a week, I'm not at home for the moment
The 3 inps don't start for me too, clearly a use of F3 instead of F1+F2
