I keep getting this message when trying to submit a score
- simpsons99
Re: I keep getting this message when trying to submit a scor
Is there a time table when this is getting fixed?
I got one score through..
Went to do my next one No go Joe!
Arcade Game Scores
Arcade Game Scores
Maybe when Zwaxy wakes up and figures out exactly why unzip is failing?
- simpsons99
So the scores should submit once this is fixed?
Arcade Game Scores
Arcade Game Scores
- simpsons99
How is saulonpb getting all his scores through? I'm starting to wonder if it's a Server thing causing this?
Arcade Game Scores
Arcade Game Scores
I copied the first attachment to the MARP server and successfully unzipped it using the same command as the website script uses:
So I don't know what the problem is.
I've modified the script so it should display any errors from the unzip command.
Please try again and paste the results here. Thanks!
(marp) tmp $ mv "Mirax %28set 1%29 score 69%2C420.zip" x.zip
(marp) tmp $ /home/dooglus/web/exe/unzip -l x
Archive: x.zip
Length Date Time Name
143675 12-23-12 11:11 mirax.inp
143675 1 file
(marp) tmp $
- simpsons99
Zwaxy wrote:I copied the first attachment to the MARP server and successfully unzipped it using the same command as the website script uses:
So I don't know what the problem is.Code: Select all
(marp) tmp $ mv "Mirax %28set 1%29 score 69%2C420.zip" x.zip (marp) tmp $ /home/dooglus/web/exe/unzip -l x Archive: x.zip Length Date Time Name ------ ---- ---- ---- 143675 12-23-12 11:11 mirax.inp ------ ------- 143675 1 file (marp) tmp $
Just tryed another one i could'nt get too submit...
Here's the message i got it was alot longer this time around..
some kind of error with the zip file - couldn't unzip it
command: './exe/unzip -l bea99_miraxa_125010_wolf146' error: unzip: can't find bea99_miraxa_125010_wolf146, bea99_miraxa_125010_wolf146.zip or bea99_miraxa_125010_wolf146.ZIP, so there.
correct the bad stuff and resubmit, or whinge to Zwaxy
- Mirax (set 2) score 125,010.zip
- (114.31 KiB) Downloaded 373 times
Arcade Game Scores
Arcade Game Scores
Looks like saulonpb just keeps attempting it until it works. Sometimes up to a dozen-odd attempts.
- Mr. Kelly R. Flewin
- MARP Knight
The big question I have is... could it be a version of WinZIP at fault here. Like a new version that has been updated to runs compression slightly differently and older versions [Or other unarchiving programs] can't unzip it properly?
Just my 2 cents
Just my 2 cents
- simpsons99
mahlemiut wrote:Looks like saulonpb just keeps attempting it until it works. Sometimes up to a dozen-odd attempts.
I tryed submiting my last score maybe 20 times in a row... Same Error message over and over again.
Seems like saulonpb is really the only person getting any scores through. I have been lucky to get 2 scores through but those where on the first trys.
Theres something that has happened since i did my Dark Tower Submit.
I know there has been problems with the submit scores will the page not being found after you submit scores But your score would still be added.
Arcade Game Scores
Arcade Game Scores
I don't understand why this suddenly stopped working, but I've fixed it now.
I was using an old copy of the unzip binary, which wasn't able to unzip files from within the web hosting folder, but was able to if I copied the files to /tmp/ and then tried to unzip them.
I've now switched to using the system /usr/bin/unzip binary, and that seems to be working.
- simpsons99
That seems to be working for now .. Thankyou for everything. Hope it stays working .. I'm sure it can be replaced or updated later.
Makes me feel better to not fight to get a score through!
Arcade Game Scores
Arcade Game Scores
I guess there could have been some change in the file/folder permissions setup after last week's server restore...
- simpsons99
maybe but it had been a few days since that had happened.mahlemiut wrote:I guess there could have been some change in the file/folder permissions setup after last week's server restore...
Arcade Game Scores
Arcade Game Scores
this is happening to me today, with the new wolf150 games.
anyone else having this problem? or have i screwed something up?
what is the best program to set as default for opening zips?
cheers!
cheers!
seems ok now.
