573,800 Stage 15
For reference the default difficulty was first changed to Difficulty 4 in Wolf145. In Wolf144 it was still Difficulty 1.mahlemiut wrote:Which default settings should we use? 0.106 (Difficulty 1) or current (Difficulty 4)? (And explains why BeeJay makes it look so easy)
Hmmm.... I didn't realise there had been a change to the defaults.... it's a real pain for those of us using older versions of Mame when someone from the MameDev team finds new information to suggest what the "factory defaults" should have been and updates Mame accordingly... I only use 106 because I'm lazy and already have it setup, etc, etc.... I actually use the command prompt to do the recording and subsequent playback test.mahlemiut wrote:Which default settings should we use? 0.106 (Difficulty 1) or current (Difficulty 4)? (And explains why BeeJay makes it look so easy)
Maybe we're going to need special rules for Time Pilot, to say it's allowed to use difficulty = 1, as deleting all the old recordings is probably a bit draconian...mahlemiut wrote:Since it'll just be deleted later since it's using easier than default settings, I'll upload it here.
Not personally, must have slept through itBeeJay wrote:At least it was no-where near the 7.0 earlier this week just off the coast of "The Naki"... did you feel that one up your way Barry?!?
I play with keyboard. It takes some practice, but once you get used to it, it's not so bad. One nice thing about the keyboard is it is less tiring doing the constant wiggle back and forth you have to do on this game with a keyboard than a joystick. Control is still harder with a keyboard though and not as precise.Alessandro.S wrote:Someone mentioned this being hard with a keyboard ? For a total newbie as myself it's impossible
