Funky Fighter
Funky Fighter
http://marp.retrogames.com/inp/9/8/5/sa ... olf123.zip
http://marp.retrogames.com/r/funkyfig
Seems to go out of sync at one of the first punches.
Alessandro.S
- MARP Serf
Re: Funky Fighter
Plays back fine for me - 11080 first stage, 2070 second stage => total 13150.
Even with sound on, and responds correctly to F10.
SDLmame 0.123 + wolfmame patches under Fedora 8.
Re: Funky Fighter
using wolfsdlmame in fc7 (and also another laptop with an intel chip) i get the same 600 point score, i did notice this:
7406.10b ROM NEEDS REDUMP
7407.11b ROM NEEDS REDUMP
my crcs are
524288 Defl:X 388816 26% 12-24-96 23:32 04a214b1 7406.10b
524288 Defl:X 377193 28% 12-24-96 23:32 635d4052 7407.11b
my crcs are
Alessandro.S
- MARP Serf
Re: Funky Fighter
I also get the redump warnings, but game replays fine:
INPVIEW: using layout type 'standard'
Extended INP file info:
Version string: 0.123 (Feb 6 2008)
Start time: Sat Mar 22 17:37:49 2008
Playing back previously recorded game funkyfig
WARNING: the game might not run correctly.
End of playback - 13159 frames - Average speed 99.996530%
Average speed: 99.93% (222 seconds)
This SDLmame is compiled for 32bit Pentium-M (Centrino 1.8Ghz).
Re: Funky Fighter
the warning we expect, but what are the crcs of those two in the funkyfght.zip rom?
Alessandro.S
- MARP Serf
Re: Funky Fighter
OK, finally figured out which switches for unzip to get the crc...Chad wrote:using wolfsdlmame in fc7 (and also another laptop with an intel chip) i get the same 600 point score, i did notice this:
my crcs are
Archive: funkyfig.zip
TORRENTZIPPED-AAAB2F94
Length Method Size Ratio Date Time CRC-32 Name
131072 Defl:X 21615 84% 12-24-96 23:32 0f47d785 7401.1h
262144 Defl:X 236092 10% 12-24-96 23:32 5038cc34 7402.1e
524288 Defl:X 207732 60% 12-24-96 23:32 ad0f5e14 7403.3c
524288 Defl:X 405448 23% 12-24-96 23:32 aa4ddf32 7404.8b
524288 Defl:X 361196 31% 12-24-96 23:32 fc125bd8 7405.9b
524288 Defl:X 396787 24% 12-24-96 23:32 04a214b1 7406.10b
524288 Defl:X 386881 26% 12-24-96 23:32 635d4052 7407.11b
1048576 Defl:X 762750 27% 12-24-96 23:32 9efe4c60 7408.13b
1048576 Defl:X 765663 27% 12-24-96 23:32 064082c3 7409.4b
1048576 Defl:X 747995 29% 12-24-96 23:32 0ba67874 7410.3b
1048576 Defl:X 679205 35% 12-24-96 23:32 1e9c73dc 7411.2b
7208960 4971364 31% 11 files
Re: Funky Fighter
darn i was hoping it was an altered rom, oh well, anyone else have luck or lack of? I still can't get it to work.
Re: Funky Fighter
Always plays back to 600 for me, regardless of throttling/frameskip.
Re: Funky Fighter
Strange ... It playbacks fine to me (note that as i try many new submitted games, during this period, i try to playback every inp).
Alessandro.S
- MARP Serf
Re: Funky Fighter
I can upload somewhere my SDLmame Linux binary, if anyone wants to try that one under another Fedora8.
It's a bit largish though... 31638104 bytes to be precise
and depends on the following libs:
[root@sandman bin]# ldd /download/linux/mame/sdlmame/sdlmame0123-wolf-bin/mame
linux-gate.so.1 => (0xb7f71000)
libexpat.so.1 => /lib/libexpat.so.1 (0x07719000)
libz.so.1 => /lib/libz.so.1 (0x00d81000)
libm.so.6 => /lib/libm.so.6 (0x00d34000)
libSDL-1.2.so.0 => /usr/lib/libSDL-1.2.so.0 (0x46126000)
libX11.so.6 => /usr/lib/libX11.so.6 (0x4304b000)
libXinerama.so.1 => /usr/lib/libXinerama.so.1 (0x432b5000)
libc.so.6 => /lib/libc.so.6 (0x00bd9000)
libpthread.so.0 => /lib/libpthread.so.0 (0x00d66000)
/lib/ld-linux.so.2 (0x00bba000)
libdl.so.2 => /lib/libdl.so.2 (0x00d5f000)
libxcb-xlib.so.0 => /usr/lib/libxcb-xlib.so.0 (0x43149000)
libxcb.so.1 => /usr/lib/libxcb.so.1 (0x4302d000)
libXext.so.6 => /usr/lib/libXext.so.6 (0x4318f000)
libXau.so.6 => /usr/lib/libXau.so.6 (0x00dbf000)
libXdmcp.so.6 => /usr/lib/libXdmcp.so.6 (0x00dc4000)
Now going to see how well the wolf 0.123 patches apply to SDLmame 0.124
Re: Funky Fighter
if you do, you should bzip2 it. Somehow i don't think it's the executable, it may have something to do with system architecture and not the code, like our set A/B problem of mame63.
Re: Funky Fighter
Do note that INP functionality is quite broken in 0.124, which is why there hasn't been any release as yet. I'd doubt that SDLMAME is any different in that regard.Alessandro.S wrote:Now going to see how well the wolf 0.123 patches apply to SDLmame 0.124
Alessandro.S
- MARP Serf
Re: Funky Fighter
dipports113 needs a few changes, but it doesn't look hard. Of course I don't have a firm grasp of what it actually does, so perhaps I'm underestimating the effort...mahlemiut wrote:Do note that INP functionality is quite broken in 0.124, which is why there hasn't been any release as yet. I'd doubt that SDLMAME is any different in that regard.Alessandro.S wrote:Now going to see how well the wolf 0.123 patches apply to SDLmame 0.124
inpview12-123 applies with fuzz except for the emu.mak, but that's trivial.
As per wolf123, it has five failed hunks - I may give it a shot Sunday, now it's bedtime as tomorrow I'll have a 3-hour drive to go to a friend's wedding.
@Chad - yes, I would of course have bz2'd it
Re: Funky Fighter
Alessandro.S, no, i actually don't think it will work because i have the same patches applied to the same architecture here and it didn't work in 123. I didn't notice you were going to aplpy them to 124. barry is right, he already scolded me (like he seems to do pretty often) for thinking just changing the wolfpatches to match the 124 source doesn't fix the inherent problem with inps that are broken. I'm assuming that they tried to fix the timing issues for input lag but didn't realize that when you make an input it has to be recorded on the correct side of the frame you are recording to get played back right, just assuming though barry might be more enlightening if the problem is worse.
Alessandro.S
- MARP Serf
Re: Funky Fighter
OK, got it - will wait for a fixed release then, in the meantime I'll keep playing 0.123. Thanks !
