Ms. Pac-Man Energizers Last Challenge
- Button Slapper
Yip, that command line works for me as well. Thanks Zhorik. You don't have the ROM designation of mspacman, which is apparently why it works...
You missed the pear NotMan! But thanks for sharing. This was the fastest I was able to do this without dieing:
http://ca.youtube.com/watch?v=wWpgdjhXW0o
Never did figure out a consistent, repeatable way of doing this for the slow levels.
shoot, i've tried the gambit, all of these "Error: failed to load state" I always get a blue rectangle in the upper corner that goes away after an enter after typing, but after that i get the failure quickly. All of these are after renaming the exectuable name and/or state file names.
wolf106 -pb mspacman -state a
mamep106-vc -pb mspacman -state a
mamep106-vc -pb mspacman -state mspacman-a
mamep106-vc -pb mspacman -state c
mamep106-vc mspacman -pb mspacman -state c
mamep106-vc mspacman -pb mspacman -state mspacman-c
help?
help?
- Button Slapper
Ok, Skito! Did you put mspacman-a.sta in STA directory.
To test save state files
mamep106-vc mspacman -state mspacman-a (or -state a)
It should load save state a file right away instead of seeing the start up screen.
To playback:
mamep106-vc mspacman -playback mspacman -state a (or mspacman-a)
NotMan
To playback:
NotMan
- Button Slapper
- Button Slapper
Exactly. And in fact it WON'T work if you DO specify the ROM. It will on your machine, but it won't on anyone else's... See, you have to read the details about what someone is saying. Don't just gloss over it. Don't assume I'm a complete idiot just because I'm new... Your command line won't work on Zhorik's machine either. Ask him.NotMan wrote:hmm... I guess it work without telling mame what game it is.
It automatically just load the playback and state state itself.
NotMan
mamep106-vc mspacman -state mspacman-aNotMan wrote:Ok, Skito! Did you put mspacman-a.sta in STA directory.
To playback:
NotMan
this still says failure to load state, maybe there is some load in an ini file somewhere.
