Replay Bounties III
- destructor
- MARPaholic
mameplus114u3. Samplerate 44100, DirectDraw. Autofire. Playbacki fine but no crosshair. The same problem with crosshair is in official MAME version. Crosshair is during play but during playback no crosshair. Mystery game. I still search version for better crosshair work, it is strange to watch replay without crosshair.
- zombraid.zip
- (480.2 KiB) Downloaded 249 times
- destructor
- MARPaholic
mameplus109. Samplerate 44100, DirectDraw, frameskip 0. Autofire. I test playback with F10 only -> fine. There is old crosshair version, we can see it
Finished.
- zombraid_mplus109.zip
- (445.1 KiB) Downloaded 292 times
Destructor has won the following bounty:
ROM: zombraid
f) Finish the game and kill the final boss: $50
To get to the final boss you need to use crystal codes:
* Crystal Codes :
Level 2 - The Crystal Code is posted at the end of the level, on the 2 pillars framing the wrought iron gate (below the head with the horns).
Level 3 - The Red Crystal is obtained at the end of the level in the elevator.
Level 4 - The Blue Crystal is hidden in a statuette on a pillar (the statuette resembles the level 2 famous head with the horns).
Level 5 - The Green Crystal is obtained at the end of the level by killing the 2-heads monster.
To fight the final boss, the Crystal Codes seen on level 2 should be inserted : Red, Green, Blue - if not it is assured death.
ROM: zombraid
* Crystal Codes :
- destructor
- MARPaholic
I know that in game are more secrets. First secret is on stage 1 -> enter to tree. Inside is Lighting weapon. In game is Silver bullet weapon but I didn't found it.
I search it long time when I begin game on whole elevator and no red orb
You must destroy all zombies from elevator for red orb
Excellent game. Now I must found right wolfmame version for normal finish game. It is possible without autofire and without autofire hand. Easiest -> game must be no miss, use lighting weapon.
EDIT
Game not must be no miss. You must have good weapon during game -> shotgun, fire, lightning. Strongest are fire and lightning.
EDIT
- destructor
- MARPaholic
Finished, wolf80, autofire. Second secret entrance discovered. Score 221630.
- zombraid_wolf80.zip
- (251.13 KiB) Downloaded 252 times
- destructor
- MARPaholic
- destructor
- MARPaholic
Wolf106 again, this time cheats were off during recording. Please disable cheats for playback. For me playback with no problem, no coin error.
click
wolf106gui-vc version.
EDIT
I record wolf109 replay, coin error during playback
Why in mameplus109 no coin error? Luck?
click
EDIT
- destructor
- MARPaholic
- destructor
- MARPaholic
