Phil Lamat - irrmaze
kranser
Post by kranser »
Hi,
I can't get any of Phil Lamat's irrmaze recordings to playback. They always bring up the setup menu on running the inp.
I have tried with wolfmame 0.101 with -nosound and -noafs and -fs 0, to no avail.
Other irrmaze recordimgs by other people work fine.
Any suggestions? Does anyone else have problems playing them back [obviously some people can play back as they are confirmed]?
Kranser.
I can't remember having trouble with this game, it might be the dreaded set A/B problem, but i thought that was resolved before 101. I had no issues using full nothrottling fs11 to play this back.
http://marp.retrogames.com/r/irrmaze
all pb fine for me ;
did you erase cfg ?
no nvram created before on your HD ? (this game generates one)
kranser
Post by kranser »
Phil Lamat wrote:all pb fine for me ;
did you erase cfg ?
Yes, I removed those two files before playing, and it didn't work.
I can play back JYD's recordings fine, but I tried all 4 of yours and none of them worked?
It could be Wolf101 related - maybe something was fixed since .101? Do you intend to make a recording in Wolf114 [bit difficult now that you have the high score though!]?
At least it runs ok for most people though - for me it hangs on the I/O CHECK 1/3 screen of the [F2] setup.
Kranser.
You will have to wait for another inp (lot of work + preparing WCC).
Did you try :
1-after erasing mame.cfg and/or mame.ini
2-after erasing hiscore.dat
2-to put mame.exe & rom in a separate folder
Note that I used the cli version
Works fine for me. GUI version.
wolf101.exe I have in the same folder as wolf 83 and 87, I didn't deleted cfg file :P
I don't have hiscore.dat file.
kranser, out of curiosity, can you look inside your wolf101.zip file (or add wolf101.exe + wolf101.dll to a zip file) and return the crc of these files so we can see if it is the same file we are using, just by chance there was an "extra" wolf101 version made sometime.
kranser
Post by kranser »
Chad wrote:kranser, out of curiosity, can you look inside your wolf101.zip file (or add wolf101.exe + wolf101.dll to a zip file) and return the crc of these files so we can see if it is the same file we are using, just by chance there was an "extra" wolf101 version made sometime.
Hi Chad,
I didn't download the .zip file, I downloaded the .exe file:
7,352,595 wolfmameplus-0101.exe
Which installed the following programs:
241,664 mame32ip101.exe
26,624 mameip101.exe
39,649,280 mameip101lib.dll
Both of the exes fail to run the recording.
Kranser.
