I've tried two xp systems amd and intel and this doesn't get passed chicago @ 44775.
http://marp.retrogames.com/inp/c/6/2/dt ... wolf80.zip
http://marp.retrogames.com/r/rampage
what did notman use to confirm it?
Rampage
- destructor
- MARPaholic
- destructor
- MARPaholic
Well... did you check to make sure that you disable NVRAM directory. DES's replay was recorded on ASM 68k core. I'm not sure what the cmd line are, but it does works under GUI.
Rampage is part of Bally MCR and it does suffer from M63 bugs. Demolition Derby is one the worst and it does have serious pb problems after M63 - M92 or maybe after M114??? I haven't even tested after M92 :/
NotMan
NotMan
oh yeah it's the set A set B issue, and weehawks xp is in the same set as notmans xp which is I am not a member. damn i'll have to resurrect my 98 to attempt to play this back again, maybe des will record again to make a higher record with a later wolfmame.Chad wrote:just verified i get most of the same results when i play these back in win98, they still work fine with xp for me, so it is a xp/98 thing, but my 98 is weehawks xp.
- destructor
- MARPaholic
