esprade
zlk
esprade
Post by zlk »
Buttman's esprade doesn't work. It plays back to 3.2m for me:
wasn't expecting this one to work, darn cave games, but it did the first time to the stated 9m score and wolf104 version
on a side note, i don't think i was ever able to playback bbh's 12m score as it's been unconfirmed for 2 years, now plays back fine with the mame63 command line version.
NotMan
Post by NotMan »
Buttman's replay desync at 1.06m and it doesn't work, due the bug on Wolf104. The best ways to get it working is play Wolf99 or earlier. Wolf100-106 is broken on cave drivers.
Not a single editor in MARP is not interested to put special rules on Cave drivers except uo poko, donpachi, progear and few others. :( So anyway, Team AVIA is still going to upload their cave replays in Wolf100-106 w/o knowing their replays doesn't work.
Skito! How do you manage to pb buttman's replay w/o desync?
Later,
NotMan
Hi :)
Butman's inp playback fine for me but only with the -window command in the cmd
Just after beginning the playback, I press F11 for the throttle and F10 to be in FS 11.
I took several snaps but not the last because i thought that i could see the hall of fame but buttman inserted a 2 nd credit (not used) which block the appareance of the hof.
I precise that in fullscreen, the game doesn't playback for me.
NotMan wrote:Skito! How do you manage to pb buttman's replay w/o desync?
Later,
NotMan
i really dunno! this one will be zeroed since 3 can't play it back (even though i can). and i'll have to try it again, i'm assuming it won't work multiple times, since i was never able to playback these before... No body has changed special rules, i'm sure because they haven't doubly confirmed the issues or don't understand them. I certainly don't when i got this one to playback (once so far).
Note i also played it back in window mode... might be something.
I know there's a problem when I can't playback *my own* replays...
EDIT: And yet, this one playsback for me... Now I have no idea whatsoever what the problem is.
zeroing postponed, two+ can play this one back... buttman is good for now. I can even play it back full screen, unthrottled, fs11.
NotMan
Post by NotMan »
Buttman's replay works for me. I just had to reset the CPU core and it pb just fine. No idea where the bug was coming from. :)
NotMan
zlk
Post by zlk »
Change the CPU core from C to ASM and the replay works. I am not sure why the player is using the ASM core, or if this is some weird bug.
Dave_K.
Post by Dave_K. »
Given the problems mentioned above, which wolfmame should be used for making Cave game recordings?
I recommend anything between 0.68 and 0.99. 0.99 is preferred.
