http://marp.retrogames.com/inp/f/d/7/al ... olf103.zip
might be a diff file issue but this one doesn't get passed first round. if anyone has the chd please try this one and see if it works or not.
killer instinct 2
killer instinct 2
Tried with diff and with deleting the diff. Alpha didn't win the 1st round.
I can't get the other kinst2 replay to work either:
http://marp.retrogames.com/inp/3/d/5/rw ... ame103.zip
- Button Masher
ok Alpha's will be zeroed when marp is back up, but Rik's recording is also in jeopardy.
This one actually passes three matches before going out of synch. Does anyone know if removing the diff file is required for making this game able to playback?
- Button Slapper
- Button Slapper
OK, here's another replay, so if anyone has nothing better to do then they can try this one. I deleted the dif file this time so there shouldn't be any problems (famous last words). If this one is OK then I guess I can have my previous recording deleted or something?
- kinst2.zip
- (35.75 KiB) Downloaded 419 times
To be sure, remove or rename the relevant .cfg, .nv, and .dif file.
.hi files don't need to be removed as MAME ignores these when -record or -playback are used, but the mere presence of hiscore.dat is known to affect a few games (mostly Psikyo shooters). Best to remove hiscore.dat if you use it.
.cfg files don't generally cause problems either, but it helps to be sure, especially if you don't need specific key or DIP switch settings. (Key settings can be set in a ctrlr .ini file anyway)
