TG3 version and settings saved
Locked
Matteo Barbieri
Post by Matteo Barbieri »
I am in the 3rd tournament and I have a few questions
1) TG3 isn't created in order to set the difficulties to the TG settings by default?
I found out that my record with ladybug that I did with win32tg3 was done in easy mode instead of medium.
2) Is there a way to preserve the tg settings between different sessions of the game?
It's quite annoying to set keys AND dip switch settings every time I try to record a game for the tournament.
Thanks in advance
rns_madmat@hotmail.com
I'm not sure about win32tg3 mame but the dos tg3m35.exe you can run
regular mame with out -recording, set the settings that are in the
tournament, hit escape, and then the next time you run tg3m35.exe
your settings will be the same.
One special note, if you use win32mame36b16 etc after you have used
win32tg3mame your saved settings will be overwritten, if you use both
versions of these games their "saved configuration" files are not
compatible and you'll have to backup the .cfg and .hi files between
playing with different versions of mame. Otherwise i think if you
set the settings by playing mame with out recording and then run mame
again to record your settings should be saved as the last version
that saved them.... there's proly more on this topic but hopefully
that will help.
churritz@cts.com
Locked
