The "On Deck" game
- TRB_MetroidTeam
- MARPaholic
Using 1 + 2 will not avoid leeching IMO. Something will exists still.Weehawk wrote:So, how would it play out if:
1) You could only shoot 1 parachute in between shooting planes.
2) You could only shoot one bomber in between shooting planes.
3) Once the mothership appeared you had to kill it before shooting more than 10 more planes (or 20 or whatever)
Would be better if the "3" use "time" instead "number of planes"... maybe 20 or 15 seconds (sometimes I need a lot of seconds to defeat the motherboard, for sure!)
- TRB_MetroidTeam
- MARPaholic
Please watch my input and answer if the part I wrote below is banned or not. Is it?TRB_MetroidTeam wrote:...My current best at MARP, I played level 2 straight up, catching a lot of parachutes... however I dont played it to INFINITE leeching (if I want, I think is possible just catch parachutes and shot minimum or nothing other planes). IMO this (go up) is the best way to survive the level 2 without deaths! So I think I don't leeched at the level 2 BEFORE the "boss" (called "motherboard" here). Of course I used leech at boss 1 and boss 2, just due TGTS.
So, just watching my level 2 (from start, still the parachute's end / the boss), I don't leeched... and this question is very hard to someone (John) to decide.
http://marp.retrogames.com/inp/e/4/d/tr ... wolf78.zip[/quote]
Minor correction, you don't shoot the parachutes, you run into them to collect them.Weehawk wrote:So, how would it play out if:
Also you have to shoot quite a few planes (I don't know exactly how many but I think its close to 50) to get the boss/mothership to appear, so you could still do a LOT of leeching (probable ideal of like 45 x 5K = 225K, so for each of levels 1 and 2 on the first 2 cycles is potentially 900K). It would also make verifying an INP very difficult and tedious. If imposing an outside limit, I think a time limit is better than counting in game actions.
For a boss/mothership time limit I think you'd want at least 30 seconds since some times it takes a while to line up a safe shot. If using a time limit I think it would be easier just to make it per level. 5 minutes is way more than you'd need per level; it would encourage leeching right up to the time limit and probably wouldn't really be valid for MARP submissions due to leeching. Different levels in a cycle might warrant different time limits since they play quite differently.
-gastrainga
- TRB_MetroidTeam
- MARPaholic
Agree. Agree. Agree.Zhorik wrote:Minor correction, you don't shoot the parachutes, you run into them to collect them.
-gastrainga
Hmmm... So wich will be the solution???Zhorik wrote:Different levels in a cycle might warrant different time limits since they play quite differently.
Is there a problem with current marp rules then?
Hard to come up with better rules, because nature of the game.
...This has been discussed at regulation forum not so long time ago.
Mame default settings are allowed at marp. No leeching.
If this game would be tracked by stage reached...that would not take leeching problem away completely...because someone could leech points, that would give a good reserve of ships...which would help get at later stages.
Also limiting [time/parachutes/planes] per stage seems a bit artificial solution.
I'd hate to start clocking or counting stuff, when replaying an inp
You should know yourself when you're leeching or not, honestly. It's quite easy to spot leeching when playbacking too, if you have played the game a bit.
For GEGOTW, it's your choice if you want to use harder than marp rules...ex time limit or TG settings.
(IMO, possible semi-marathon is not so bad thing, make the buggers earn their money )
Marp rules are against leeching. May it be parachute scabbing or plain plane shooting...Weehawk wrote:Given the following constraints:
1) GEGOTW submissions must be legal for MARP Regulation play.
If you do want to change TP rules for marp...then that discussion should be at viewtopic.php?t=119292) If at all possible, I want to avoid using time as a limiting factor.
What would our best options be?
You appear to be deliberately avoiding killing the mothership/boss on Level 2.TRB_MetroidTeam wrote:Please watch my input and answer if the part I wrote below is banned or not. Is it?
The Special Rules for the game only mention "parachute scabbing", but I would say you are in violation of MARP Rule 2h which reads, in pertinent part:
"...you must keep moving to complete a level."
To repeat my question:
That is, in terms of setting objective criteria to require progressive play.Weehawk wrote:Given the following constraints:
If none are palatable, I have no problem with leaving the question subjective and judging adherence to Rule 2h myself in each case.
I agree that if you have unlimited lives, you can leech to get more lives, even if scoring is based on level reached. That was the main reason I proposed 5 men only. "5 men only" also helps to limit game length, which IMO is nice for competitions (both for players and verifiers). Its also got precedent as tournament settings on many other games (e.g. Robotron, Joust, Q*bert). And while you can't set the game to only five men, its pretty easy to verify scores (if you can count to 5 ). Artificial time limits would be a pain to verify. I've heard that Jeff Peters could marathon Time Pilot on factory settings without any leeching (although I'm a bit skeptical), so "5 men only" also heads off any potential marathoning.The TJT wrote:Is there a problem with current marp rules then?
I challenge the assertion that it is easy to see and judge leeching on the game. Attached is a zip file which includes a number of recordings for the first level (using Wolf95). The file timepltn.inp represents playing the first level as fast as possible, while still targeting all squadrons that come out and collecting all parachutes that come along. It only scores 32,400. There are also 6 other recordings that use a variety of different tactics to try and press point on the level. They score between 56,000 and 119,100. None of them involve infinite leeching tactics. I find it unlikely that we (much less all other parties) would agree on which ones constitute illegal leeching.
No one was discussing changing MARP rules for TP, this discussion is only for what rules will be used for next week's GEGOTW competition (and hopefully may set a precedent for TG).The TJT wrote:If you do want to change TP rules for marp...then that discussion should be at viewtopic.php?t=11929Weehawk wrote: 2) If at all possible, I want to avoid using time as a limiting factor.
-gastrainga
- timepltslowplay.zip
- (52.65 KiB) Downloaded 821 times
Might be a good opportunity to test this.Zhorik wrote:I've heard that Jeff Peters could marathon Time Pilot on factory settings without any leeching (although I'm a bit skeptical)
I would say that if I cannot see it, it is not in violation.Zhorik wrote:I challenge the assertion that it is easy to see and judge leeching on the game.
This is why I suggested objective criteria, but no discussion has followed along these lines.Zhorik wrote:I find it unlikely that we (much less all other parties) would agree on which ones constitute illegal leeching.
To address each inp Zhorik attached:
timeplt1: Deliberately slow play, but that is not a violation of 2h.
timeplt2: I see no problem there.
timeplt3: I don't have a clue what I'm supposed to be questioning about this.
timeplt4: No problem
timeplt5: No problem
timeplt6: There is an instance where two parachutes are collected without shooting any planes in between. This would obviously fail any objective criterion set for minimum number of planes which must be shot in between, but subjectively I would not DQ this recording based on 2h.
Here is what were the "slow play" tactics I used on the recordings:Weehawk wrote:Might be a good opportunity to test this.Zhorik wrote:I've heard that Jeff Peters could marathon Time Pilot on factory settings without any leeching (although I'm a bit skeptical)
timeplt1: 119100 - Always shooting at least one plane between picking up parachutes, but trying to limit it to one to maximize number of parachutes. Died once. Theoretically probably close to 250K is possible on a single level. I've practiced this a bit more and gotten over 150K.
timeplt2: 65300 - Only shooting at squadrons and collecting parachutes. Trying not to shoot individual planes since they score lower than squadrons. Note: Killing squadrons counts as kills towards the end of level.
timeplt3: 63400 - Firing continuously, but trying not to shoot anything to maximize the number of parachutes. Picking up as many parachutes as possible along the way.
timeplt4: 56000 - Firing continuously in an arc pattern, but trying to only hit squadrons and collect parachutes. Also stopped shooting right before triggering mothership to make sure I got one more parachute. This is pretty close to the way I normally play this level.
timeplt5: 66600 - Firing continuously, but in bursts of 3 and trying not to actually shoot anything to maximize the number of parachutes.
timeplt6: 85100 - Only shooting at squadrons and collecting parachutes. Squadrons came out less frequently than in timeplt2 so score is higher, but I targetted every squadron that came out.
timepltn 32400 - Clearing level as quickly as possibly, killing all squadrons and collecting all parachutes along the way.
Oh, and on most of these I took an extra couple of passes before taking out the boss/mothership to squeeze in a few extra points.
In my opinion 2,3,4 and 6 are definitely ok. I'm not so sure about 1 and 5. If 1 is allowed, I'm sure that it is the best method to maximize points. Using it at least 300K is practical on the first 2 levels (its easier and you can score even higher on level 2 than level 1, thanks to the big planes). Of course it would take practice to do this clean and without losing too many ships.
John, I'm sure you realize the problem with you judging what is leeching (or even reaching a decision on this thread), is that regardless of what we decide here, if it gets ruled leeching on the regulation forum, then it isn't valid as a MARP submission. You could always adopt the criteria that all submissions not get zeroed by MARP, but that might make it hard to determine the winner in a timely fashion. I still think 5 lives/level reached would be fun.
-gastrainga
- TRB_MetroidTeam
- MARPaholic
My last proposal... (maybe against a lot of the MARP current conceptions... scores, time involved): To GEGOTW, what do you think about Time Trial to this game? Maybe... default settings, fastest completition of the 1st "world" (ie: 1 loop... I forgot how many stages is it... 6? ).
Well, after the thoughs, why to run a game with bad settings to competitions, in a very short (1 week) competition??? (Including cash prizes)
I never played this game before Robert announces about DECA 2005... this is not my style of game, however I liked this game... but exist the problem I wrote above... I am seriously thinking in avoid to comment about the rules... will never be reached a perfect rule. Good luck for you try to reach the "the best current solution" to this problem.
- destructor
- MARPaholic
