Safety Spot
Gorf Safety Spot
It doesn't work in the gorf ROM set with current versions of MAME. If you notice, the screenshot above was from the gorfpgm1 ROM set which is better emulated. It worked in the arcades too, but the emulation for the gorf ROM set is not very accurate and has a lot of other problems besides just the safety spot not working.
-gastrainga
-gastrainga
- AL
re....
Gaz: just leave the last laser guy,and then go extreme left and extreme up.
Should work. Must be a MAME thing. It worked in the arcades. Maybe a newer rom version made it impossible. I used gorfpgm1 ROM set .
- AL
re....
And while we're at it, lets not forget about the old Defender safe spot.
Collect all ten humanoids, wait until there are no enemies on screen, and land those MF's....
Only really works on wave one, unless you are a master. But gives you an opportunity for an early smoke etc....
- defe0000.zip
- (1.31 KiB) Downloaded 1795 times
Novice
- The greatest info supplyer
Re: Safety Spot
Raiden #8 last.
I think this is the KING of the safety spot.
- king.jpg (33.71 KiB) Viewed 51016 times
DEFence CONdition
WAR 1<< >>7 PEACE
WAR 1<< >>7 PEACE
Novice
Re: Safety Spot
raiden II boss 5.
there are 3 positions.
A:side
B:back
C:front
ABAABABAABCBAABABAABCBAABABAABCBAABABAABCBAA .
after 44th attack(A), boss will escape.
A:side
B:back
C:front
- 0002.png (30.53 KiB) Viewed 46569 times
DEFence CONdition
WAR 1<< >>7 PEACE
WAR 1<< >>7 PEACE
Novice
Re: Safety Spot
1941 last stage middle boss.
this enemy is not very easy.
safety or 350,000points which do you want?
- 0000.png (31.22 KiB) Viewed 42291 times
DEFence CONdition
WAR 1<< >>7 PEACE
WAR 1<< >>7 PEACE
