Posts: 1972 Joined: Fri Sep 20, 2002 9:38 am
Post
by destructor » Sun May 02, 2004 12:59 pm
-noscanlines
emphatic
Posts: 28 Joined: Sat May 01, 2004 10:03 am
Post
by emphatic » Mon May 03, 2004 2:21 pm
Didn't work either. I had to work with Soundcard=0. And all I get is really choppy playback. And incorrect (as I guess that dying on the first thing that appears isn't part of playing like a master.
Too bad.
Emph
Post
by destructor » Mon May 03, 2004 4:22 pm
Do you install DOS drivers for you soundcard? Is soundcard work correctly in DOS (with drivers must be software for test music and samples)? If this all is OK then playback must be OK.
1. cwsdpmi.exe
2. mame.exe rom_name -rompath path_to_rom -noscanlines -playback inp_name
Inp file must be in "Inp" directory.
3. and next choose SounBlaster from menu.
Posts: 4191 Joined: Mon Feb 04, 2002 10:05 pm
Post
by mahlemiut » Mon May 03, 2004 5:16 pm
DOS drivers are useless for Windows XP. There simply is no DOS.
Post
by destructor » Mon May 03, 2004 6:15 pm
Yes. But if Emphatic boot from second disc 'win98' or only 'prompt mode' then he can use DOS drivers.
Post
by mahlemiut » Mon May 03, 2004 6:32 pm
And the HD is only going to be readable if it's FAT32 format. Win9x/ME cannot read NTFS disks.
Post
by destructor » Mon May 03, 2004 7:54 pm
Yes if disk is in FAT32.
emphatic
Post
by emphatic » Tue May 04, 2004 11:13 am
Mahlemiut's got a point there with the disc format. I only have NTFS drives.
And even If I did go through hell and installed Win98 just so I could watch the Psychic5 playback, I just feel that I have too much of a life to do it.
Emph
Post
by destructor » Tue May 04, 2004 1:41 pm
Create Fat32 partition.
Post
by mahlemiut » Tue May 04, 2004 6:02 pm
Problem #2: Win9x must be installed on the first partition on the disc.
Post
by destructor » Tue May 04, 2004 6:09 pm
Bleh
Why? There is no way for use partition managers?
DaviL
Posts: 202 Joined: Sat Oct 12, 2002 7:16 pm
Post
by DaviL » Wed May 05, 2004 6:01 pm
I had the some problem.
I just resolve it. What I do ?
I reinstall win 98se.
Yes, I know, I'm a geniuos.....
Post
by mahlemiut » Wed May 05, 2004 6:09 pm
Talk about extreme downgrade... anyone replacing XP with 98 must be nuts.
DaviL
Post
by DaviL » Wed May 05, 2004 6:26 pm
My computer is old.
Much problems with XP.
But the only thing sure is... yes I'm a nut. But who care ?
Posts: 2562 Joined: Wed Jun 25, 2003 7:43 am
Post
by Weehawk » Wed May 05, 2004 6:51 pm
I finally replaced the video card in my old Win98 machine so I could try it again.
Can run mame35b12 now...
-noscanlines was key...thanks des!
400Mhz, so not fast enough to record videos or anything
