Sonicwi2
Sonicwi2
this one is confirmed and i'm thinking it will playback with dosmame and sound, but me and bbh2 can't get it to work..
http://marp.retrogames.com/inp/1/0/8/al ... mame35.zip
Look´s like that is something we have to debate, if a confirmed recording is safe or if i can be deleted.BBH wrote:um, what the fuck? a score getting zeroed after it was confirmed? it plays back just fine here.
Tried again with 44100 samplerate, it will still not work, anything else you can suggest? and is 22050 not the default samplerate for the old mame versions?BBH wrote: how? uh... DOS MAME 0.35 and 44100 samplerate... what else could affect it?
storm
OS : winXP
cpu : P4 3gzh
OS : winXP
cpu : P4 3gzh
well perhaps samplerate doesn't make a difference then. I don't know what else it could be, other than these sound options I have in my mame.cfg...kfx wrote: Tried again with 44100 samplerate, it will still not work, anything else you can suggest? and is 22050 not the default samplerate for the old mame versions?
ym2203opl = no
ym3812opl = yes
samplebits = 8
I think that it should be more safe than an unconfirmed, but I still think that some should be able to make a playback or else it´s of no use. And since BBH can make it playback I think it should stay and not be zeroed.The TJT wrote:Confirmed has been safe till now. (and should still be)
storm
OS : winXP
cpu : P4 3gzh
OS : winXP
cpu : P4 3gzh
now now, all that we needed was an explanation... and because of it NOW two people CAN play it back with known settings. I got it to work with bbh1's settings with a forgotten added option.
oplfm=yes
kfx try that, it should work with sound and fs0, damn tough eyeball boss, gets to second loop stage 14 . You see, if bbh hadn't have said that: someone (me) would have to go through all the damn sound option permutations. So, damn right, i'm going to zero a score if someone or the author can't tell me and two other people how to play it back, when it's this easy to do for them and it's shit hella hard for me to figure out.
score reinstated and confirmed.
bbh2, you'll have to use dos mame on this one (and find a 98 machine since nt,2000,xp won't run dos mame with sound.)
oplfm=yes
- Baby Bonnie Hood
- Button Masher
