The following inp playbascks fine in tgmame66:
http://marp.retrogames.com/inp/bs_dragw ... mame66.zip
Regards
Dragon World II
when you become a confirmer you can confirm this, so you can keep track of these personally, (this forum topic group is really for inps that don't playback...) it's ok to post here with things you can playback, but normally you should only post when you can playback a recording, when someone else has already posted that they can't play it back. keep on confirming :)
As at the moment I am not a confirmer, I put here the inp that I review (that aren´t confirmed). Both the ones that playback fine and the ones that don´t playback.
If I become a confirmer, I logically will put here only the wrong ones.
But in order to help the MARP comunity I put here all. Do you want to send you an email with the ones that playback fine instead of create a new topic in this forum?
Regards
Regards
oh, no. what i was saying is that you will probably be a confirmer sooner or later, so you could just save these links for yourself to confirm later when you do have that privilege :) your help is appriciated. But if you saved these up, you could boost your confirm count when you first become a confirmer rather than having someone else (like me) steal the confirm from you and get credit for confirming something you origonally found to playback.
