Ultimate Tennis
Ultimate Tennis
http://marp.retrogames.com/inp/phl_ulte ... mame65.zip
Loses sync after winning the first game of then second match. Won't start with sound disabled. Used Win32 console.
tried twice and played this back twice usign -fs0 -nothrottle and -fs11 on xp, wins 4 matches as advertised, wouldn't rule out the mame_rand on this one. Did phil use 65.1 or 65.2? I couldn't playback phils earlier utenis recording, this one happens to playback for me.
or maybe I've used m64tg3, I was not sure when uploading
I'm at work for the moment, will check tonight
I've checked : it was recorded with dos64tg ; can you playback it better , Barry ?
It's worse. :?
this is the same symptom we were having with puzzlop, it would work for some and not for others in pre amame65.1 (mames with out mame_rand fix). PHIL: try next recording in 66 (which i think has the random fix) or in alphamame65.2...
Looked through the Art & Magic driver, and sure enough, there are two instances of rand(). It would be useful for it to be tested, so if someone wishes to in a regular MAME build, here's what I did.
In src/drivers/artmagic.c:
Line 22: insert line #include "machine/random.h"
Line 158: change to prot_output[0] = mame_rand();
Line 248: change to prot_output[0] = mame_rand();
gosh doesn't someone at mamedev know how to use fgrep? :)
