Can't get the ones recorded with Windows versions to play pack correctly (Can't try the DOS ones).
I recorded my own game with MAME .61 and can't even get that to work.
Danny Sullivan's Indy Heat
yeah, the special rules for leland type games need to be updated and it appears even the random seed help with mame60 doesn't help these which still MUST be recorded with out sound and with out nvram. Buttermaker, you should be able to record with out sound personally, if you can let me know. i've always been able to make useless recordings (usually ones that pass the first/second rounds in leland games) when recording with sound, but playback fine when recording with out, enough proof to automatically remove recordings that don't playback with out sound... Ocean views playsback fine with out sound and has been confirmed.
Buttermaker
http://marp.retrogames.com/inp/ped_indy ... n37b13.zip
http://marp.retrogames.com/inp/ra_indyh ... mame60.zip
http://marp.retrogames.com/inp/rcl_indy ... mame60.zip
http://marp.retrogames.com/inp/kal_indy ... mame56.zip
These do not work even without sound.
http://marp.retrogames.com/inp/tbm_indy ... mame61.zipButtermaker, you should be able to record with out sound personally, if you can let me know.
