just wanted to see if this is right:
for defender, you do the same thing,Game that requires Service Mode(F2) "On" at startup(1):
All atarisy1-sy2 games(i.e 720,rampart,atetris and so on)
(1)What I mean with this:Run MAME with the game that you want to play(without recording it)press F2(the service button),quit.Now record with the same game,then leave the service mode after some time,then play.
Without the cfg file(or if you want to do it faster)you can try to press F2 at the first play(on the ROM/RAM test),but I don't know if it works too...
Tested with DMAME .36/.61 ,don't know other versions...
start up, get into service mode...EXIT
then start the playback again, and it
should work properly..
is that right?
i'm using win61, and windows 98se2..
later
n e gat ive 1
