K5 Round 1 - Over Top (Elimination)
Post by Weehawk » Wed Sep 06, 2006 9:23 am
destructor wrote:You can made boost on:
- motorbike
- plot
- 'water car'
Using the Falcon, you mean.
I also get a boost from the Dio (for some reason I don't think the 350 ever gets put next to me) but it's not as good as the Plot or the bike.
Post by The TJT » Wed Sep 06, 2006 10:04 am
destructor wrote:On start hold buttons A and C and LEFT direction. You must wipe off vehicle on your left side. It's work as set match to fire.
No wonder, I was going RIGHT...
Could get a slight boost, getting 3 seconds under the default 27,5s with falcon. I guess getting more advantage depends on which cars you get at the beginning=luck?
You said you must go slower than car in front...if so, then you can't catch that car in the first place(second boost). Do you slow down speed of your car after going past other vehicle(second boost)?
Sorry Matt, I was being frustrated having played bike for some time and realizing that no matter what the top positions would not be reachable. Well, it *is* frustrating, and you could not know beforehand about the trick.
zarouk
Post by zarouk » Wed Sep 06, 2006 12:24 pm
Hi all,
Update :
3'42''42
Motorbike
WolfMame 0.106
overtop-zarouk-34242.zip
(13.24 KiB) Downloaded 153 times
Post by destructor » Wed Sep 06, 2006 12:30 pm
The TJT wrote:You said you must go slower than car in front...if so, then you can't catch that car in the first place(second boost). Do you slow down speed of your car after going past other vehicle(second boost)?
Yes.
Motorbike example.
Motorbike is on my left. I hold A + C + LEFT and boost on motorbike, pass motorbike on right (I still hold A + C), next slow down speed (let A) - motorbike must be still on screen (control it with A button). Next motorbike approach to me (I control speed using A boutton, not too slow, not too fast), when motorbike is on my left I press LEFT and A to wipe off motorbike for second boost. Now my speed is 500km/h :D
Remember, hold C still until second boost. And manipulate A button.
On plot is the same method almost. Sometimes is possible second boost without slow down.
'Water car' is slower than Falcon and first boost is weak. After first boost you must approach to 'water car' and slow down speed and next made second boost. Sometimes second boost is possible without slow down.
EDIT
This score I made using Ultimarc UltraStik360 joystick which I installed yesterday :D Excellent joystick. No switches. Very comfortable.
sikraiken
Post by sikraiken » Wed Sep 06, 2006 12:36 pm
destructor wrote:I saw this technique is sikraiken inp (-inpview) and next learn in 3-4 games.
D: Maybe I should have saved the technique until the end of the round. ;) I'm kidding. But, in one of the next rounds, you can give me a technique, alright? :D I'm glad people found it helpful anyway. I'm sure someone else would have figured it out if I hadn't.
xanadu71
Post by xanadu71 » Wed Sep 06, 2006 1:15 pm
Davil will not be your friend if you use technics of others :D
sampras
Post by sampras » Wed Sep 06, 2006 5:17 pm
My poor INP - 3,29,26
kid_overtop_32926_wolfMAME106.zip
(13.74 KiB) Downloaded 163 times
DieseL
Post by DieseL » Wed Sep 06, 2006 7:59 pm
3'29"30 :-s
wolf106
overtop32930.zip
(10.34 KiB) Downloaded 152 times
Post by TRB_MetroidTeam » Wed Sep 06, 2006 9:00 pm
For sure Falcon is better, however I didn't have time to "learn" their techniques. It is all from me. :-)
3'23"07
w101
bike
TRB_overtop_3'23''07_wolf101.zip
(17.96 KiB) Downloaded 161 times
saru3000
Post by saru3000 » Wed Sep 06, 2006 10:06 pm
A very slight improvement.
wow_overtop_32262_wolf106.zip
(13.32 KiB) Downloaded 151 times
Post by mahlemiut » Wed Sep 06, 2006 10:30 pm
3'26"18 - 0.106 - Falcon (Stealth Black)
br_k5_overtop_32618.zip
(9.87 KiB) Downloaded 151 times
Moreno
Post by Moreno » Wed Sep 06, 2006 11:11 pm
won_overtop_bike_32814_Wolf106.zip
3'28"14
(24.08 KiB) Downloaded 147 times
Post by BBH » Wed Sep 06, 2006 11:37 pm
just a reminder, there's less than 22 hours left in this round, and 7 players that haven't submitted anything yet...
saru3000
Post by saru3000 » Thu Sep 07, 2006 12:33 am
This game is now burned into my tiny brain.
wow_overtop_32115_wolf106.zip
(12.8 KiB) Downloaded 143 times
jbd41
Post by jbd41 » Thu Sep 07, 2006 1:40 am
3'28'13'' (Motorbike)
*sigh*
jbd_overtop_32813_wolf101.zip
(9.17 KiB) Downloaded 144 times
